Wood Stove Guys..............Come Here, Please
- Replies 18
- Views 9.6k
Mopar1973Man 4 posts
dorkweed 3 posts
MarbleCrusher 2 posts
JAG1 2 posts
Guys, once the weather breaks here, I'm gonna tear out the "zero clearance" or "pre-fab" metal box type fireplace in my house. My plans are it put a wood stove in its place. I've done the research and such on doing this. It involves taking the current fireplace chase (which is in the garage) totally out, as well as the existing fireplace chimney. I had though about using the existing chase in the garage, but it's actually gonna cost more in the long run because I'll need numerous double wall chimney pipe bends.........30* ones to follow the existing chase..............$$$$$$$So what I plan on doing, and this could change, is close up the wall where the fireplace was, frame it up, insulate it and put cement board in it's place so I can do some sort of tile or stone heat deflector behind where the stove will be. For the floor; and this depends on the stove you get, I place on building my own hearth out of layers of durock(cement board), and Micore 300(insulative product), with tile or stone over. Sound Kosher guys???:pray:As of now, I'm leaning towards these stoves.................Jotul F3CB, Jotul F400 Castine, Pacific Energy Alderlea T4, and Morso 2110. Is it better to "go bigger" than you think you need??? The wood I get around here, is usually "gnarly" and not real straight, so a tiny firebox would be a pain. But then again, I don't want to have the stove heat the stove room at 85*+ either. I'm scrounging up wood now as I type this, because these new EPA stoves require very dry seasoned wood to perform properly. I've scrounged up about a cord so far, and have about 1/2 cord in my shed, because I was concerned about using the POS fireplace this year. I've got a neighbor down the street that said I could get the rest of the trees in his yard........about another 2 cords.................it's ash, but it's free!!!:thumbup2:Any insite is appreciated!!!
