- Replies 45
- Views 23.2k
98whitelightnin 21 posts
Rogan 7 posts
Haggar 6 posts
JOHNFAK 4 posts
Got it pulled yesterday and hopefully will get it put in thursday. First thing you will notice is we put safety first.
Got it up on blocks and jackstands and looking at it made me feel weary but after getting under it I felt good. Got a the sawzall out and cut the floor for easy access and then had to cut the crossmember out because it had been welded. After all that we pulled the bolts out of the bellhousing and then the clutch and flywheel. Two bolts in holding the clutch on gave us a problem but we finally got them out. Clutch and flywheel looked almost new and the trans had writing on it like it had been rebuilt so hopefully all is good.
