new dash and hvac box rebuild
- Replies 18
- Views 11.6k
I went the buildi g supply and picked up the closest thing I can find to the remnants that were left in there. There is more than one kind in it. Matched it the best I could. Did not have to mess wit
I have spent the past 2 days of my weekend replacing my severly cracked dash and a leaky heater core. In the process I also replaced my ac evap core. My heat had gotten to the point of the only way to regulate it was thru the windows. By that I mean the heat on full blast and opening a window when it got to warm, which was not to often since hy heater was not putting out alot anyway. I installed a new core and the Heater Treater part I heard so much about. The oe part for the blend door was broken and I am glad I had it on hand.I bought a replacement dash from LMC. The color match was spot on. The fit was very good. It was a fairly straight forward replacement. 90% of the screws were not to difficult to install, but the other 10% were a challenge. I used Mike's article for the HVAC rebuild for most of the work, but got a little inventive on doing both the HVAC work and the dash installl. I have pictures and will try and write it up in the near future as to what I experianced while doing both. I will say that the time frame posted for these were exceded by quite abit and if you attempt either one allow some extra time. Since this was my first time taking a dash apart of any kind, the unknown mutiplied the time frame that I needed.I would also like to add that I would never had even attempted something like this had it not been for this forum. The members here give so much confidence and info I feel notthing is impossible. Thanks guys.
