I started the swap earlier, im gonna wait till it cools down a little outside to proceed. I have only taken the bumper off so far. Will post pics as I progress.
  • Replies 79
  • Views 13.2k
Got it running this evening. Runs great, started up easier the first time than it used to when I changed the fuel filter with the vp. http://youtu.be/irop_9WEm5I
NICE! ..looks like its hot/humid!!!
It's Aaaaaaaaalllliivve !!!!!!!I'm not going to lie I might be a little jealous
It's Aaaaaaaaalllliivve !!!!!!! I'm not going to lie I might be a little jealous
What he said. The P7100 is cool.
Now the only problem I'm having is all but one of my lines are leaking fuel. I tightened them to 25ft pounds like Scheid said and it just is not enough. Scheid said if they don't stop leaking to send them in and they will lean test them but I don't need a test to know they are leaking.
I guess they just needed a good drive to quit leaking because they are all dry now. I am a very happy camper! ;)
What's it like ?
I don't thinks its as fast as the comp and smarty. I may have it timed a little low so I might mess with that a little but it runs great. Motor is quieter too
How is it doing with the injectors at VP pressure?How's the smoke compared to VP w/ 7x.010's only?
Now I'm curious of you MPG's compared to the VP44... Up or down? I know I got to wait till you run a tank of fuel being P7100 pump cannot be used on the ScanGauge II.
Runs great but I think I will go ahead and pull the injectors to get pop off lowered. Smokes more on start up and I have to tap the throttle every time to start it. Its not as smoky just driving around as the comp and smarty stack was when it was turned up all the way though. My buddy has my scan gauge but I hope to get it back this week so I can keep up with my mileage closer.
Won't work you can sell the ScanGauge II now... :duh: Since you now have the P7100 there is going to be no feedback of fuel data. Not to mention the rash of all the error code from the ECM still hunting for all the missing devices. The only device that will report correct error codes will be the PCM. You'll have to go back to old tyme method of fill the tank math method.
98, What did the kit cost you? I am not planning an install, but I have deal on a complete 95 driveline near me and I am trying to gauge the cost. Its a good deal on a parts truck basically.I guess on CF and whatnot I see 2000-2500 as the going price for a complete P pump kit.
I never could get the SG to read correct mpg anyway, I used it for the other features. I have $150 in cash for all the parts from the 12v truck including pump. With lines and all little pieces including sending my fass back to fass to get a new motor and all I probably have about $1000 total out of pocket in it. I sold my vp, smarty and timbo apps to the guy I got all the 12v parts from. I also sold my 24v gear housing to a guy on cf. if you can buy a donor truck for a decent price, you can get most of the parts you need and sell what you don't to pay ft te swap.
Holy crap. I thought selling the 12v motor would have cost you $1500 to 2k. I am looking at getting the truck to flip or to part out.
I didn't buy a12v, just all the parts I needed from it. If you can source a 12v for a good price, I say go for it, especially if your vp is dead. My truck was perfectly fine when I did all this but I can never leave good enough alone.
