Weird Engine Grunt Maybe Timing?
- Replies 71
- Views 10.3k
TFaoro 26 posts
Mopar1973Man 7 posts
Wild and Free 6 posts
Ilikeoldfords 6 posts
Ok I can't seem to figure out what the noise my engine makes. I just installed my edge comp box yesterday (Not wire tapped) to make sure everything was going to work properly when I do decide to tap the pump. Now when the engine is down in the lower rpms and i stab the throttle I get a slight loss of power, and a terrible "grunting" sound. To me it sounds like the timing is WAY off from what is should be, But as soon as I build a couple pounds of boost the horrible noise goes away and the power comes on instantly. I have no codes, smarty is set to stock, FP is 15wot 19idling. IP is 2 1/2 months old. I thought I had read somewhere that if the MAP sensor voltage is way low it will change the timing, but I could be wrong. Any thoughts?? Sorry for the paragraph I'm just baffled Thanks in advance
