DIY: Lockup Switch install into Gear Selector Arm
- Replies 24
- Views 10.8k
Me78569 6 posts
Russ Roth 4 posts
cbrew 4 posts
The_Hammer 2 posts
I decided to go through the trouble of installing a Momentary switch in the gear select arm. A Momentary switch means that it will only connect the circuit if the button is pressed. As soon as you release the button the circuit closes. IE: Pressing it will complete the Ground and trigger the Torque Converter to Lockup, as soon as you release the button the Torque converter lockup will release. This fixed the issue of forgetting that the switch was on when coming to a stop. I found that in the cases where I wanted to use the lockup switch I was already using my right hand to shift down or disable OD. It was only natural to think that a lockup switch on the Gear Selector would be nice.
This DIY is not for how to connect the lockup switch, You can see how to do that by clicking here.
Sorry for the blurry pictures.
You can use any switch you like, so long as it fits. The switch I used was 1 Black Momentary Off on Push Button Horn Switch | eBay
Your switch should be no deeper than ~1/2"
This will require taking the truck out of park to adjust the shifter, so ENSURE YOU APPLY THE EBRAKE AND CHALK THE WHEELS BEFORE YOU START.
Article for this mode is found below.
Edited by Me78569
