Since its cold out and I don't want to go outside unless I have to, I thought I would start a mood lifting  thread for all to share in. I will start.
  • Replies 151
  • Views 29.4k
  • Wild and Free
    Wild and Free
    The Texas Department of Employment, Division of Labor Standards claimed a small rancher was not paying proper wages to his help and sent an agent out to investigate him.   GOVT AGENT: I need a list
  • Dieselfuture
    Dieselfuture
    This farmer has about 500 hens, but no rooster, and he wants chicks. So, he goes down the road to the next farmer and asks if he has a rooster that he would sell. The other farmer says, "Yep, I'v
  • War Eagle
    War Eagle
    A US Marine enters the Catholic Church confessional booth in Jacksonville, FL. He tells the priest, "Bless me, Father, for I have sinned. Last night, I beat the sh** out of a   flag burner and an
that tire is off my trailer from Dripleys exhaust when he passing.
4 minutes ago, IBMobile said:
That's why I use all season nitrogen.
I always got a laugh out of the whole nitrogen thing. By volume, dry air contains 78.09% nitrogen, 20.95% oxygen,[1] 0.93% argon, 0.04% carbon dioxide, and small amounts of other gases.
I always just imagine behind the "we nitrogen fill" signs is a normal air compressor hahahha
Nitrogen filled tires is a huge safety item and especially in large tires in certain industrial areas where one doesn't want any more oxygen from a blown tire feeding or fueling a fire or even a tire fire.
I would bet that in 99.9% of the automotive tire shops they are wasting time and money if they are filling with nitrogen.
Having had training in tires and tire safety coming from the mine industry where tires can run up to the $250K each price range for some tires longevity is key.
To properly fill a tire with nitrogen the correct way is extremely time consuming and unless one has access to a bulk liquid nitrogen supplier is a waste of time for those who claim to fill them with nitrogen.
To do it correctly requires the tire be seated to the bead and aired up to ensure it is sealed and then aired back down and pulled into a slight vacuum but not to unseat the bead, then the nitrogen filling starts and it needs to be filled with nitrogen and drained down into a vacuum 2 times and then a final fill of nitrogen to get a near pure nitrogen fill. See the issue here?
It is much more stable and does help tires last longer and the pressure doesn't change with temp differences like normal atmo air plus like I said it is the safety issues as well when it comes to fire ect.
Back on track.
Edited by Wild and Free
11 hours ago, Me78569 said:
I don't see any apples :whistle:  must be his nose.
Last Minute Valentine's ideas....
