- Replies 25
 - Views 12.6k
								pepsi71ocean 6 posts
								Yankneck696 4 posts
								Mopar1973Man 3 posts
								GSP7 3 posts
Report:
Took My alternator off and to a local Alt/Starter rebuild shop. To double check it for bad diodes. My alternator bench tested OK . He then took the back off and to check the diodes individually with a meter, and I had "1" bad diode
I was charging Volts: D.C. 14.30 and My A.C. was .055+/-
Moparmans video, he checked Volts at: DC 14.25, AC .005-.015 IIRC
The Alternator Shop (Jason) Ordered a new Rectifier/diode pack about $25 and Im putting in new brushes $9.00 as long as I had it apart.
The above numbers are a reference to go by .
My Alternating Voltage Test A.C. .055+/- I thought was ok , But I did actually have 1 bad diode. There are 8 diodes on the diode pack
I will recheck my AC volt reading with 'New/Good Diode Reference' when reinstalled the Alt. with its new diode pack
Rick
Edited by GSP7
