  1. Glowshift and DiPricols tend to be cheap for fuel pressure gauges... http://www.glowshiftdirect.com/ http://www.danininc.com/
  2. Cool let us know how it all turns out... I love to see pics of your setup when it done...
  3. It could be hunting for idle mode and causing a governor problem...If you got a small rat tail file I would open the holes on the APPs sensor slightly to try and reach the set voltage... Just don't get carried away filing...
  4. LOL I've got the 235/85 R16 on mine now and pulling 25.2 MPG on my last trip to Stanley, ID... Skinny tire do perform just fine for highway use and tend to be just a bit slick in the gravel but if you keep a level head you can do just fine...
  5. Try some of the vendors I've got listed... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm
  6. Sorry the only way to fix this problem is to replace the VP44... Sorry...
  7. Still I would check the fuel pump relay it supplies power to the VP44... There is a fuse in the PDC for the VP44 (Engine)...Here is a short video of that...
  8. Mopar1973Man replied to a post in a topic in General Conversations
    That's part of the problem the price of the entire setup is huge... In my 4K Watt system I've got over $20,000 in inverter, batteries, solar controller, solar panels, pelton wheel, pelton wheel generator, gasoline generator, wiring, etc... I prodcue if I'm lucky 500-600w per hour on a sunny day and pelton wheel runing full tilt. I store enough power for 8-10 hours battery wise but with winter days coming I lose my pelton wheel because of the lines got to be drain out... Then when gets storm like Dorkweed it stay like that for days... So solar power isn't worth anything... So my summer power bill is about $30 a month but come winter time its about $150 to $180 ... That's with all wood heating! 8|
  9. Ok... P1689 check the fuel pump relay in the PDC, Check the fuses in the PDC as well... If that is all good the the VP44 injection pump has failed... P0122 is APPS sensor code (Accelerator Pedal Position Sensor) that has failed go give Timbo a clal for a replacement... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/apps-replacement.html
  10. Little insight... The VP44 has the ability to run without a lift pump but does serious damage to itsself when the fuel pressure drops below 10 PSI... Lift pump test and pressure requirements... http://mopar.mopar1973man.com/cummins/2ndgen24v/lift-pump-diag/lift-pump-diag.htm Then how to pull error codes... http://mopar.mopar1973man.com/cummins/2ndgen24v/obd2-error-codes/obd2-error-codes.htm
  11. Hmmm... I can't answer that one truely because I kept my stock filter and fuel heater for that purpose. But if you would want to add it back its simple just go to Vulcan Performance and get a Big Line hose for between the filter and VP44. Just a few bucks... ;)
  12. Got your phone message... ;) Dorkweed has a point the programmer could be a cause of this problem. ECM info and wiring diagrams http://mopar.mopar1973man.com/cummins/general/ecm/ecm.htm Voltage drop test http://mopar.mopar1973man.com/cummins/general/voltage-drop/voltage-drop.htm I would check over all wiring. Like I know the system ground for the ECM and sensor is right behind the starter and cannot be seen without removing the starter. I would check over the charging system to be sure it charging properly. This means having the alternator diode checked (Don't skip this!) What ever is going on is a electrical issue. So make sure the battey cables and main feed line, fuses, etc are all in good shape. Like I've found main fues for the PDC that have CRACKED but not blown so when the load would increase the fuse would break OPEN and the item would fail till the fuse cooled again. Bad or weak battery cables could make the alternator work excessively and might casue voltage spikes or unusual voltage levels. This also includes bad grounds. The only thing I can think off is having a Dealer DRB III tool scan the system for faults this goes a bit deeper than just a typical code reader... Check CCD network bus (voltage and terminatation), VP44 (commuication), etc...
  13. I guess some guys over at CF.com did some trying of different 2 cycle oil and found that Valoline is better in performance qualities. Now as for long term data I don't have much on it...
  14. Here is the factory fuel pressures... It might cause hard starting issues... But there is a thread over at CF.com about high fuel pressure. http://www.cumminsforum.com/forum/98-5- ... ssure.html
  15. Nope... Pureflow sent that to me... So it a factory bracket for the AirDog 150. Just request that style of bracket. The other bracket flat mounts the pump to the frame rail... As for the big line kit you can find them here...(For the other guy)... http://www.vulcanperformance.com/Draw-S ... /ffvpu.htm
  16. Way too high... 8| 10-20 PSI is normal... As for the steering column... http://www.autometer.com/cat_mountsdeta ... dl=62&gw=0
  17. That one feild I'm not that great with is Axles and Ring and pinion... :red
  18. Oil pressure sender might just be stuck internally... I would verify this with a mech gauge and see what you pressure actually is... If different then you know you got to replace the oil pressure sender...
  19. I kept my stock filter and fuel heater... Also I even left a filter in the stock filter housing... So far no issues running this... But I kept it because Idaho winter are rather cold... 8|
  20. Think about it... Today ULSD fuel is 520 HFRR...
  21. That's impressive for MPG 25.77! You got me beat... ` But I've been hauling heavy lately with 2-3 cords of firewood and trailer in tow... So I don't expct much for MPG'
  22. What is your fuel pressure like? Also did you do the lift pump diagnostics? http://mopar.mopar1973man.com/cummins/2ndgen24v/lift-pump-diag/lift-pump-diag.htm Bump the starter to activate the transfer pump. Look for air bubbles. If no air bubbles are present, proceed to step 10. If bubbles are present, check the lines/connectors between the fuel tank and the transfer pump for conditions allowing air to be drawn into the fuel system. Correct the condition and repeat steps 6, 8, and 9 Most of the fuel system is a vacuum line so leak never leak outwards but they sure suck inwards without leaving a wet spot... Speed sensor is in the top of the rear diff... The P0500 error code explained here... http://mopar.mopar1973man.com/cummins/2ndgen24v/abs/abs.htm (Bottom of the page!)
  23. If your getting fuel for even 5 cylinders it should start... Because Cummins has a 3 cylinder high idle mode for winter time operation so it will run on 3 cylinders if there is enough fuel. So my money is on the the fact you might have a dead VP44...
  24. Yes you must tap the wire... Edge Comp fuels with normal de-fueling (2,700 RPM) Edge Drag Comp fuels all the way to 3,200 RPM (redline). Edge Juice (Hot) will act just like Edge Drag Comp Adrenaline I'm not sure of... I'm pretty sure there is a setting/program to all it. I think the Smarty does it too. BD Has a box too... http://www.dieselperformance.com/index. ... /index/43P
