Winterization...
Thank you... I've got them installed already ofr this winter now... But the day time temp are still rather high so I might pop the bottom row out to add a bit more air to the coolers... But Morning temps are low 28-34*F here... 8|
Stickers!!!
Here ya go... I got them done finally... :thumbsup I even did one for a buddy's 92 Cummins... >
My forum
:nono You never Spell Cummins with a "G" LOL
a 2 stroke oil question?
Standard interval as usual... 2 cycle oil doesn't effect either the engine oil or the fuel filter changes...But use the standard 128:1 ratio. ! oz of oil to 1 gallon of fuel... :thumbsup
Speedometer question ??
Not a problem that's what I'm here for... :thumbsup
New to this site
There you go signature area... LOL ucp.php?i=profile&mode=signature
New to this site
Welcome to my little forum... I know you active vendor so I gave you your own access so you can advertise products here... I'm not going to push for payments for advertising right now. But maybe in the future you might toss a donatation to the M73M.com site.As for Not owning a Dodge that's fine... By chance what do you own and maybe I'll get busy and create a area for you to handle if you crazy enough... I'm not very knowledgeable of fords or chevys but I do understand the basic functions... :thumbsup
I got a buddy "Taz" that's got the same issue... His does it for 10-15 miles... Then comes back... :confused: It's electronic and controlled by the PCM in the fender. There is a sensor in the trans...(Or transfer case). No error codes... :confused: Here is the flash code listing for them... http://mopar.mopar1973man.com/cummins/general/error-codes/error-codes.htm
4:10s MPG
4.10 gear makes it rather hard to get big numbers but 21 is nothing to sneeze at... 8|
Edge Mileage Max Module
Also you lose the timing advancement when you boost exceeds about 5-7 PSI... You can hear a change if you got a smoke switch... :D
Im a New B . . .
That why the limitiation was setup. Because once you go to far the burn characteristic change considerably. Hence a change in power and MPG. I've got some people using 2 cycle oil to add lubricity back to fuels like JET-A and others that need it and they are between 1/2 gallon to 1 gallon of 2 cycle oil per tank. But since in there case they are getting the fuel for cheap rate it offset the cost of 2 cycle oil. As for myself I spend $64 bucks a year on 2 cycle oil for 20K miles basically. (128:1 Ratio) ;)
Starter brushes and contacts
I brought this over from TDG.com for others! :thumbsup
General OBD II listing...
Here is a good site that list error codes for all makes of vehicles... I kind of snagged it from MnTom's site (Midwest)... LOL http://www.canobd2.com/default.aspx
2 Stroke and the Common Rail
Using 2 cycle oil with a CAr isn't bad. Dorkweed here is using 2 cycle oil in his 2004.5 and also got a CAT. The one you don't want to use in is the DPF (Diesel Particuate Filter)
Stickers!!!
Final change...
Stickers!!!
I got one more change to make here really soon... I got a suggestion to drop the www from the head of the address and re-center it. I might get it done in the morning... :thumbsup
Stickers!!!
Small change up...
Stickers!!!
Well... I just got done doing a computer job yesterday for some people in Riggins, ID. They wanted me to move software for the vinyl cutter from a laptop to a desktop computer. I couldn't resist looking at all that fresh vinyl in the back room.. So I had to draw up a windshield banner for my truck... Sorry to say I'm advertising everyone else on the back glass but the front is going to be mine! The artwork is 5 foot wide and 7 inches tall in raw form... By monday I'm going back to town and have it cut... What you guys think??? :confused: (Sorry the pics is chopped in the right... ".Com")
Price of fuel where you live ?????
Hmmm... $4.239 now... Riggins, IDWe topped out at $5.059... 8|
Smarty
Don't feel bad my last tank is slipping too... My current ScanGauge II mileage is about 18.7 MPG... But I've been driving with a slightly heavy foot and driving alot of dirt roads and steep roads... :confused
Winterization...
I'll stay down here in my hole... Thanks... (2,800 ft) LOL So you like my change up in my signature... ;)
Is the ABS hyper-sensitive in these trucks?
Either the sensor is bad and can't sense slow speeds or there is a problem with the rotor as for triggering the pulse... I clueless but I would love to hear what you find... Post pics I would love to learn about this one... :thumbsup
Buried my truck..
I'm normally quite good with cutting down trees... But I got to say I didn't cut this one down. A buddy was to the cutting this time... Normally I can place it just about with a mark but not always... I rarely hang a tree up...
Expensive fuel and speed!
One thing that doesn't go any is wind drag. Just going from 55 MPH to 65 MPH your nearly doubling your wind drag. 8| So speed is the important factor behind the MPG game. So if your a high profile truck with big tires, lift kit, etc you going to have to slow down even more to reduce your drag. Like you never see race cars jaked up 3 feet off the ground... They are always slammed to the ground. So using common sense and realizing since my work and terrain requires a 4WD truck with ground clearance I know my wind drag is on the bad side. So I'm going to do everything I can do to gain... Like I got a aluminum topper weighs onlly 80 pounds! But it covers the bed and gives a better profile on the truck (reduce wind drag). Speed I normally keep down to 55 MPH. This has a second advantage. Since you are traveling slower than traffic you never have to pass any one. This is a savings too... Everytime you pass a person on the highway your losing over 0.5 to 1.0 MPG for every pass you make! There is a considerable loss to having a open bed... Just the topper can boost my MPG's up another 1-2 MPG for wind drag. But remember my topper is only 80 pounds... Fiberglass topers are much heavier and might cut the wind good but will rob you of MPG's for the weight. Tires have a huge effect on MPGs... Cooper STT 265/75 R16 (left) and Michellin's LTX 265/75 R16 (right)... The michellins are roughly 20 pounds less per tire and have lot less rolling resistance.
SAE Specifications of Lubricity for Diesel Fuel
Don't get me wrong Keydl the weo/WMO can be used in a Cummins as long as you stick to a few rules it will consume it just fine... * WEO/WMO is filrered down to 2-5 mcirons before use. Only engine oil to be burned. Prefered only petroluem oils.*Dose doesn't exceed 5% by volume tops. (1.75 Gallons) But Cummins Centinel use ways less... I would stick to 1-2 quart tops and you would be able to burn without the loss...
