  1. Right here if its a banjo bolt... Bottom of the filter housing...
  2. When you shove the roll in the can it looks like this... So it cannot come un-wound or shread... I've been using mine for little over 3 years and love it. It keeps the oil clean longer and works like a chram... :thumbsup I got to change filters today anyways so I grab a pic of the old roll... 8|
  3. Lack of communication with the ECM to pull codes... You might have to check the connection on the ECM to be sure its not dirty. Then last resort is to go to a Dodge dealer to see if they can pull the codes... :confused: Its seem like the 2001 model year is having this issue the most...
  4. Yeap... I do right here... http://mopar.mopar1973man.com/cummins/2ndgen24v/valve-adj/valve-adj.htm
  5. Wow! That killer results so far there Dorkweed! :thumbsup
  6. Love to hear how the rebuild goes... :thumbsup But I got a question why are your running mismatched batteries??? :confused:
  7. For over 15 years I ran 235/85 R16 on my old 72 Power Wagon Dpdge in winter time ice and snow with no problem. Now with the diesel its a different story... I tend to have to be light on the throttle to keep it from slipping in the gravel... But come winter I can control TQ with the Edge Comp but selecting a lower sublevel...
  8. Sounds like the water hammer effect is finally beating the electric sender to death. You need to add that needle valve and then seat it closed and then barely crack it open again...
  9. Mopar1973Man replied to a post in a topic in General Conversations
    Well if I upgraded my solar panels so I was creating more than 4K watts I could sell back directly to the power company now. The Interverter has a sell back feature and protection to prevent hazards. Like the city provides the 60 Hz clock cycle so if the cycle wanders off then the intervert shutdown sell mode. lets say the power line fell or broke... Well it impossible for the invert to feed the neighborhood so if fails rapidily and shuts down sell mode... It got to admit the few time I did do it... It was wild to see the wheel in the power meter running clockwise then as soon as sell mode starts its slows down and stops... Then start spinning counterclockwise... Then all the little pointers started moving backwards... I built a program to capture and then sell at the nd of the day well I our power bill was reduced... 8|
  10. Got lucky it looks... :thumbsup
  11. Glad your OK Russ...But that is kind of funny to hear about... LOL
  12. 1. You need a fuel pressure gauge. Keep your fuel pressure above 10 PSI always2. Your going to need a upgraded fuel pump (FASS, AirDog or Raptor - You should do this upgrade regardless of horsepower upgrade or not!)3. You going to need a upgraded torque converter and valve body to keep the trans going. (You should do this upgrade regardless of horsepower upgrade or not!)4. Then you could add a enhancement box to gain few horse power to pull the load. (Edge, Smarty, Quadzilla, etc)
  13. I love it all Ford owner I run into think I'm nuts... LOL
  14. I would hit a wrecking yard and replace the whole port...Or you could try Caspers Electronics and see if they have it... :confused:
  15. I've got books... http://forum.mopar1973man.com/downloads.php?do=cat&id=2
  16. Most will point towards MOOG for ball joints and simular front end parts...
  17. I ran across this on aother forum but I still don't have a reason for the fault... :confused:
  18. Here is my stock fuel filter after 15K miles... (Before the AirDog) Nope... The injectors are not gunked up... Been running 4 years now... My last trip to Stanley, ID I netted 25.2 MPG!!! It not magic but it does help keeping the fuel system lubed up...
  19. Hmmm... No leaks at all on the ground... Well like you said you should see it either in the radiator or the ground... So is the coolant like a strawberry malt? :confused:
  20. So sad to lose good friends like a Dog... I had a white German Shepherd named "Star" she was a very protective dog but loved to show off. I had a show I pull off to new friends and stranges. I would just walk in the front door of the house and Star waiting patiently and I give her a good whack on the face (not to hurt but to get her started!)... She knew what is up and go into full attack mode and latch on to my arm and pull me to the floor shaking my arm as to rip it off... But I give the cammand STOP! she let go... Never broke the skin but it was freaky for newbies to see it... 8| She live to the good old age of 12 and started to lose her kindeys... Had to put her down... (sniff!) I really do miss that dog... `
  21. Hmmm... There is a lot of good information there Russ... I notice with just my flood lights (fog lights) the reflector isn't quite perfect and the beam pattern tend to be even worse but since they are 100w bulbs the brightness tends to compensate for the lack of quality in the optics...
  22. OMG! LOL There is a way to keep them quiet... >
  23. Go to the source... :thumbsup www.scangauge.com
