Mopar1973Man done his first VP44...
Wow! That was easier than nailing jello to a tree! I just completed do my first VP44 install. To tell you the truth its easy as hell to do and takes just about 3-4 hours to do it taking your time. I will be updating my orignal VP44 install write up in the near future. There is a few notes and shortcut I found to make the install much easier. Sad part is I didn't grab my camera... (Should of!)
Adding Forward turn signal lights?
Well then there is the standard ol' sealed beam lights you can put into rubber grommets and mount... But that gets costly quick...I still think if you get creative you can make that strip work for ya...
I wish I knew where I saw it at but I fell into a link on a forum for LED lights. The light bar was mounted below the tailgate or on the tailgate and it had Brake, left and right turn signals, backup lights, and running light all in one bar on the tailgate...Sorry I don't remember but its out there! :thumbsup
Electricity From Sun
According to the shop we bought ours from a guy could shoot the panels with a 22 rifle and it should harm it as long as the wiring naver broke. But of course phyiscal damage from hail would be a PITA. Constantly fixing broken glass panes and repairing wiring...I don't think its a good idea for you... :confused:
fuel pressure
Updated web pages and information of the site... Here is the write up for fuel pressure now... http://mopar.mopar1973man.com/cummins/2ndgen24v/fuel-pressure/fuel-pressure.htm
Fuel Mileage Increase
Hey JLWelding could you catch mine yet... :confused: http-~~-//www.youtube.com/watch?v=pq0XG5qRLsM Yes you can post YouTube videos now... :thumbsup My max on record is 25.3 MPG's... :wow
BioDiesel and DPF systems
What is going on is the the DPF re-gen process actually is causing the injectors to fire during the exhaust stroke to attempt to burn out the DPF by blowing exhaust fire down through the filter. This suppose to burn out the filter clean. Actually the 6.7L engine might have more HP/TQ but there isn't many that can hold up to the old school for MPG's...
Another "First Diesel"
Here is a write up on the ABS/BRAKE light problem... http://mopar.mopar1973man.com/cummins/2ndgen24v/abs/abs.htm Like others had said check for air in the system too...
More 2 cycle oil stories
Interesting about algae growth... I never had a issue up here but interesting... :thumbsup
No Problem... I was doing so good and screwed up the CSS scrpit and ended up starting over again... The previous version had more to it now I got to play catch up and try not to include the bad script... Back to our normally scheduled thread... LOL
Straight Piped Exhaust
I remember you saying something about that in a past post over on CF.com...
Bio-Fuel
Funny... The fuel station around here are now starting to post sticker and signs saying "No Ethanol!" LOL Other that that most are marking the pump with the the amount of Ethanol being used... I hope it follows the same sceme with diesel fuel...
no power
Well there is 2 types of turbos... HY35 (Automatics) and HX35 (5 and 6 speed trans.)The HX35 turbo has a small piece of rubber hose going from a fitting on the compressor side ot the wastegate motor underneath the turbo. The HY35 has a solid metal tube that you can't access... But regardless if you pressurize the hose or the entire system the wastegate should move to the open postiion (rod movement towards the rear of the truck). This rod can be seen under the truck very easy.
If you are good friend with your local supplier you can find out how often he services the pump filters and what condition his tanks are. Like myself I've sample fuel from my truck and several other here locally and never had a issue with water or algae growth...
Pop pressure... When the VP44 pump start to wear a bit they tend to lose a bit of the pressure so they don't deliever as much fuel...
my clutch?
Here is how to blead the system down... http://mopar.mopar1973man.com/cummins/2ndgen24v/clutch-hyd/clutch-hyd.htm
no power
Use a blow gun on a compressor and add some air to the hose on the turbo and see if it moves. Set you regulator on the air pressure to 25 PSI to see it move to open...
There you go... That all about timing and pressure (pop)...
Non OEM Alternator
Here you go... Napa link... http://www.napaonline.com/NOLPPSE/(S(vh ... 55opjgaiy0))/Results.aspx?Ntt=RAY2134011SW&Ntk=Part Number&N=0&Nty=1&D=RAY2134011SW&Dn=0&Dk=1&Dp=3
no power
Actual there is a Quadzilla problem... The Quadzilla has a full boost fooler so it impossible to have a MAP sensor code really. So it was me I would un-hook the Quadzilla and see if the Quadzilla is the cause...
Fuel Pressure Gauge
Fuel pressure gauge usually comes by itsself. So I typically order a oil pressure tubing kit and it supplies all the fittings and ferrules for the gauge and for hook up...Then you need a needle valve from NAPA for $8 bucks (Weatherhead - WH6820)
P1693 Code by Itself!!!!
Just pointing out there is more errors so if the P1693 is with another code you good... But if the P1693 is by itsself then you got a communication problem...
PCM is on the passenger side firewall... ECM is on the driver side of the block... No such thing as dumb questions... :nono
Amsoil? No Change synthetics?
Here you go... Fresh TP and Used TP rolls... 8| Reloaded can... Unsed TP paper that is spooled off to make it fit...
WEO/WMO in diesel fuel
Add it in to you fuel which is fine... Just mix it less than 1.5 gallon per tank. As for filtering it... I would filter it through a 2 micron filter.Lot of guys use a cetnerfuge to spin off the debris and clean it up better than a filter could.
