CTcummins24V
Everything posted by CTcummins24V
  1. I believe some bolts/studs go into oil galleys. When I did mighty diesel head bolts, I had to suck the oil out of the bolt holes with a vacuum and compressed air, but you shouldn't have to do that with studs. I think machining the rocker cover only applies to common rails. Are you replacing one at a time?
  2. I am painting the brackets and changing out the bushings to poly right now. I couldn't find rubber ones anywhere, other than oem...
  3. Getting the pitman arm off can be tough. Definitely need a puller, "C" puller or whatever you want to call it.
  4. Where did you get rubber bushings from?
  5. Didn't clean up the bushing mounts?
  6. Hmmm, looks good. Thanks for the input guys. Although after taking my nerf bars off...they are rotted.
  7. Another method, raise the front tires off the ground and stick a pry bar under the tire and lift up. If it clunks, ball joints or wheel bearing is bad, but someone has to be looking underneath to see what is moving.
  8. We'll see how it holds up, this is my first experience with heim joints. It might have to be customized in the future or get a true DSS track bar with bushings.
  9. RockAuto, just under $230 shipped. I just looked on their website and they don't have them listed anymore. I'll see if I have the receipt with the part #...As far as ride, I haven't driven it really. She's kind of put away for winter. The rockwell coils are constant rate and thicker than oem. They will be a stiffer ride. You might want to look into skyjacker d25s or rcx coils. My initial measurements showed that the coils and spacers netted me 3", so with 1.5" spacers that leaves 1.5" for the coils. The description for the coils said they would keep it within 1" of factory ride height.
  10. Dodge dealership or cummins? An actual cummins dealership is much cheaper.
  11. Haha awesome! It's always nice to see an unexpected friend. I didn't know you had snowys out your way
  12. I just put a 3rd gen trackbar on my truck from CPP, $390.
  13. Still haven't got an alignment, but here she is...
  14. NAPA has this one on sale now... http://www.napaonline.com/catalog/catalogitemdetail.aspx?R=NCBHCL1B8_0424510189
  15. I'm thinking of cleaning my nerf bars up this winter before they rust bad and wanted to use bed liner on them. Anyone have any good experiences? Something thick and durable that won't peel easy... Thanks
  16. RockAuto sells the actual oem parts, try them. I replaced all mine this fall and still had the light on. Come to find out the ABS module is bad, still haven't spent the $600 to get it fixed. I guess it's pretty common on all dodges in those years. Scan it before you spend over $100 on sensors.
  17. It counts rotations correct? Or is it just for the ABS module?
  18. Make sure you get an oem one, $30 on rockauto. I put one in from O'Reillys and it was defective...
  19. Rear diff sensor? Do you have a movie of the tach in action? I have had tach issues twice, once was the rear diff sensor and the other is when I had the stock lift pump wired wrong and it would run when my fuel boss was running and my tach would go haywire.
  20. 002.MOV Don't mean to hijack, but since we're talking about tachs, is this normal? It's bounced a little for 2 years in idle.
  21. Mopar filter. What converter did you go with? Stall?
  22. Next week, after I get paid and get an alignment done...and new cross over tubes this weekend to rid my leaking fuel lines at the head.
