Me78569
Everything posted by Me78569
  1. that's what I promote above 14psi no matter what, set your idle pressure at whatever it takes to keep your wot pressure above 14 psi. If you idle pressure starts getting above ~22 psi to accomplish that then you have an issue with your pump.
  2. Nope never, highest I have ever seen was 130ish cruising, Who knows what at WOT as I am not really paying attention.
  3. honestly no they have no released a set of serial numbers for old vs new. anything over 2.5 years ISH is likely good.
  4. Without the fooler I never see 143*f for IAT. I run the fooler no matter what honestly.
  5. I can add a little fuel to the fire. During one of my trips my Pureflow pump decided it wanted to start pumping 35psi instead of 20psi, due to it being 0*f out and windy I just kept going, no blown seal in my vp44. This has happened 3 or 4 times now and I have yet to have a seal blow. Now saying that ~400 miles total at 35 psi = vp44 safe at 35 psi isn;t true, but as stated above we really don't know. I have been running my pump at 23-25psi idle for 15,000 miles now and no issues with the seal.
  6. yep check your pump for leaks. This is a known issue, hence my signature.
  7. Great install location, didn't think of putting it down there.
  8. Love my Switch for both functions. safe travels Ed, see you tonight. Anyone wanting to buy Ed a beer just paypal me some money and I will buy for him tonight.
  9. I know I have them somewhere. It is in the articals on this site I believe.
  10. its a piggy pack system so yes it will work, but I don't think the edges reads coolant and iat temp from the sensors, but over the canbush. regardless it will work.
  11. That is pretty much the coolest thing I have ever heard. Makes me feel like I am 5 again watching a war movie with planes starting on the deck of a aircraft carrier
  12. blonde huh? I seem to remember a more skin toned hair color
  13. You want me to post a thread about the map? Or high idle? Or what?
  14. Here is a test of what I was thinking. 2nd Gen Cummins Owner Map Simple 2 step process to add a marker Enter your Screen name, General Location ( address is not recommended), and details in the big box. I would put what forum you are found on and terms of use of the smarty IE: 6 pack of chainbreaker IPA. If you have a smarty and are willing to let someone use it to flash their ECM please use the RED Icon. Blue is setup for users willing to lend a hand wrenching. Click Submit and Ok then you are done. What do you think Ed? If I can figure out how to embed
  15. Is your quad high idle enabled? With the quad high idle enabled delay of 10 seconds, the truck would start to idle up from the quad then die almost immediately. As soon as I turned off my quads high idle the truck acted perfectly. Ed should we setup a google maps thing of the states with icons for smarty owner locations?
  16. Big thanks to TFaoro for flashing my ecu today. Great guy Side note if you are running a quadzilla adr box ENSURE that your quad high idle is disabled before you try and turn Ed's switch to high idle. The combo of the quad bumping the RPMS up and the high idle software will cause the truck to due and it will take some time for the vp to reprime
  17. Jimmy, Great posts. I am always willing to read and listen to someone that can form thoughts into meanful senstences. Nick
  18. Pretty excited to get this going
  19. I don't have any so I threw the jack in there since it was easiest. You could through the jack on the side somewhere, but that's up to the person. I would rather have everything contained. The rest of the faceplate is pretty full. I myself don't use a tape ever so it worked good. And here I thought this was a cool QIY never thought I would get so much hate and no people going awesome hahaha
  20. Getting hard to not talk about it Ed? hahahah
