Everything posted by Royal Squire
Fuel return line
Can't you just add a hard line to what you have like dieselfuture did. Look at the photo of his basket
Because, Roadkill. If you like wrenching for the sake of wrenching, come on in.
Those guys get paid for coming up with those crazy ideas!
P0237 and CEL
Had another weird thing happen yesterday a couple times. When I went to start truck I got no WTS light, and lift pump continued to run instead of normal bump. I shut key off, waited a few seconds and everything worked normally. Hope this isn't the ECM dying
P0237 and CEL
Thanks for the reply. Was gonna try disconnecting edge but had errands to run first. About 4th time I shut it down and restarted while running around CEL went away and runs like always. Probably need to clean some connections
P0237 and CEL
Started truck this morning, was the 1st time it was cold enough for high idle to work since getting it enabled. Ran back in the house for a few minutes, when I jumped back in and stepped on clutch I realized I had a CEL. Of course I'm out of town so went to oreillys and it shows p0237/map sensor. Any suggestions where to start? It is way down on power too
What are the best headlight packages?
Mine aren't glass
Thinking of picking up a 70 power wagon...
When I was growing up, the ranch's "town pickup" was a 66 3/4 ton power wagon with 318/4 speed, and homemade wood stock rack
Pretty good looking for the age. What about maybe swapping in a 440?
New heat pump system
Global warming I guess
6 degrees here this morning! Kinda sharp drop. Yesterday at same time was 47
Billet Flexplate and Washer
Can a person add some good welds?
Turbo opinions
The lbbi shield is $152 and standalone is $400. Someday, after I get a quad......
Turbo opinions
How much is pre-built controller
Thanks IB
Is the Flosser brand important?
Timbo
I think it's 165 to your door
Thinking seriously about twins
Photos???
Squeaky Clutch Pedal
Have you ever tried a product called "Freeze Off". My son says it works well but not economical as you must use a lot for it to work
Did you torch the TC bolts?
1690 ecm-pcm disagreement help.....
Am I missing something? Why did you change the harness?
Fuel Pressure Issue
Just have Vulcan send a 1/8" inline tap that you can install in 1/2" hose between factory filter and vp44. Screw your gage fitting into that. There should be an article on this on the site somewhere
Fuel Pressure Issue
Do you have stock fuel lines? I think most folks here use a needle valve instead of or in addition to snubber that comes with gage. Someone with more expertise than I will most likely respond also
Teardown and Rebuild
Triples?
Fuel sending unit question
It takes even more head scratching if you have a short bed!!
Stutter/ throttle cut out at low speed
Sounds like it could be apps. Good idea to check for AC voltage, the process is explained in one of the articles on the site. Someone more knowledgeable will comment directly. Would be a good idea to fill in sig so everyone knows what you've got at a glance
