Everything posted by Royal Squire
Truck stolen
Glad to hear it!! Hope not too badly damaged
4th Gen. Alloy Wheel Refurbishment
You could a little red detail and the rest clear
Trailer connector wiring
You can buy a continuous duty solenoid that you run that hot wire through so it will charge camper battery only with key on. Really simple. Do a search for camper battery isolater.
How much boost?
Ok thanks. Mine doesn't hit 25 so I suppose I have a leak.
How much boost?
I'm sure this is probably covered already somewhere in this forum but I'm unsure how to search without bringing up a ton of unrelated info. My question is, when I bought this pkp it came with an edge ez, and the boost elbow had never been installed. After I got my gauges installed I installed the boost elbow, which changed max boost from about 12-15 up to 21-22. Does this sound about right. Is this boost elbow somehow adjustable? Thanks for the help
Turbo oil return hose
I appreciate the effort notlimah. It does say bottom, maybe for twins?
That photo is of supply hose
Thanks for the help guys
Pipe is dry, just the short hose looks oily
Anyone know what size hose is required on turbo oil return. Mine looks like it's getting kinda porous. Is it something special or just a chunk of oil resistant hose. Thanks
Control arm bushings
If those bolts are rusty you obviously don't have enough oil leaks!!
rv converter for the batteries.
Yes she does that regularly. Thousands of comedians out of work....... ! I guess for you guys I need to be more specific and careful of my wording. What I was referring to,was the original converter in my camper. Does it not perform the same functions?
How do I know if what I have is inadequate?
Possibly if you soak them with good penetrating oil over a period of time(week or 2), you can save the bolts.
Truck stolen
So sorry Tyler. I'll keep a look out in this part of the world.
Door rubbing issue
It's possible the striker on the door jamb needs to be adjusted also
What solder to use
You can use it to solder holes in steel and it is used for radiator repair on brass radiators. If you have plenty of length I would probably start over. However, there are others here that are more knowledgeable about these things than I am. You might wait for more responses
Travel trailer newbie!
What solder to use
Never use acid core on anything electrical. The acid causes corrosion
About to become a member of the travel trailer crowd. Gonna be delivered tomorrow morning. 2008 Jayco 25' with a slide out. Will leave on 1st trip on Friday.
Aluminum Transmission Pan Install
Lookin good !!
Got any photos?
Log splitter
The ram is fast, the downfall I see is its so close to the ground your going to be bent over a lot unless you mount splitter on a bench or something
392 Stroker Hemi Build
Looks too wide to fit!
Drum brake adjustment
I have always adjusted shoes out tight against the drum and then back them off. Don't know if it matters though
