Everything posted by Royal Squire
ABS and Brake lite stuck on
Haven't found any on this one but I have on other vehicles. I have cleaned and made a pretty good solder joint on some bu not easy.
Sometimes you can cut out quite a bit and copper is still kinda black.
Pyrometers install
Have Isspro EV gauges and wondering where the best place to install pyrometer amplifier? Would like to use someone else's experience if possible. Thank you
Nice to have speedometer and cruise working again and no lights on inst cluster. Wasnt an issue on this repair, but what is the best way to clean corroded or dirty wire, like a broken tail light wire so it can be soldered. Thanks as always for all the help.
Was pretty sure I had a broken wire, just couldn't find it. Was afraid it was up in the frame behind fuel tank. No critters involved in this break, conduit is brittle an have had a lot of ice and mud hanging underneath this winter
Never thought of that!! Need to set some traps. How big are tree rats? Maybe I could just electrify the whole truck and if any critters touch it....ZAP! Already had mice make a home in hood insulation. Maybe I'll just concentrate on repairing wires
Could not find a break in wire, checked plug at left front wheel and was clean as a whistle. So I decided to replace rear speed sensor. Got it out in one piece, used more patience than I'm used to. Struggled to get new sensor back in. Keep in mind it's been a couple weeks since I tried to find break in wire. Guess what I found after I had the sensor all installed
I think I made a mistake.. axle dump
Put a cutout on that you can control from inside the cab and have the best of both worlds
1995 2500 4x4 Reg Cab Trade
What is the welder worth?
Teardown and Rebuild
Did you find your exhaust leak?
Thought it was just front pinion seal
Thanks guys. Do I need to worry about pinion depth or just use existing shims under bearing? Do you reuse crush sleeve or?
I can see bearing is shot. This just wasn't a part of my plan. Will probably live through this.
I was hoping this was a dream.
Boy was I wrong! Was going to change front pinion seal real quick but turns out at least one of the pinion bearings is junk. I don't have the time or the money for this. Plus I gotta work outside in the mud. I hate to have someone else do the work, I could try to find a good used diff. Sure miss my old shop.
4wd System Refresh np241DHD rebuild.
Even on your lips. Haha. Was just putting on lip balm . Struck me as funny
Thanks for the help Is there a gasket between the halves or just use silicone?
It is wet from where halves bolt together back to output shaft seal. Kinda the whole back half is wet. I will check the bolts. May be loose
Is there a vent on TC. If so where is it located. Case is oily on outside but can't tell where it's leaking. Thought maybe vent was plugged. Any thoughts? Would it matter that I park with front pointed down hill?
Fluids list?
Do you not need to worry about brake booster?
Oh to be young again
You can pee 36'??
On the Hunt for a Slide in Popup camper
Won't the combustion process of a ventless heater make humidity worse?
96 dodge into 1956 ford
Photos??
New truck!!
Is it everyone's habit to see how low they can run on fuel, or just checking in case of necessity. I always try to fill up at 1/4 tank. Course I live 15 miles from fuel and need to use fuel to plow road to get to hiway.
