Everything posted by Royal Squire
My fellow wood burners!
Quadrafire pellet stove in the house we rent. Has a programable thermostat on the wall like a furnace. Supposed to be able to burn corn, pumpkin seeds, sunflower seeds and I don't know what all. We just burn pellets. House has cathedral ceiling above stove, so upstairs stays warm but back rooms downstairs don't. Still need shed for pellets, has some ashes, best to clean once a week or so. Outside of this stove doesn't get hot like a wood stove. Once in a while it has electronic glitch and shuts down or won't start. Can turn down to 50* and it will burn for a couple days if you have power.
And he said, Let there be Light!
Thanks for your help. Will have to look into how lites are disabled.
XRF Balljoints
I feel your pain! Every time I turn around I need(want) something else.
Was so much better than oem. The other question I have is my 2000 is set up for snow plow lites so when you plug in the plow it disables oem lites and enables plow lites. Any idea if this would be compatible with xenon system?
What is the difference between these and hid? I've got hids in my 98 and they were pretty much plug and play and not bothered by ribbed lenses. Lights things up pretty good. They were about 70 bucks 5 or 6 years ago iirc.
The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
You could take Genos mount and use it for a pattern. It should come with the necessary spacers, etc.
Great article! I know you have supplier and cost here, might be good to have with article. I already have clear lenses, but cost is still a little intimidating. I'll put it on the list.
Vibration
You obviously don't have much for oil leaks judging from the amount of rust I see!
KDP?!
Sorry, I can't find that tab, but as everyone else has said, they are easy to make. I like the fender washer idea.
KDP?!
Might want to consider a front crank seal while you have it apart. I think I have a KDP tab I could mail to you if your interested.
Vibration
Air soft bobs are plastic aren't they? Wouldn't it take a lot of them?
Vibration
Done my share of smashing fingers. My Dad always said to take care of your hands so when you get old they will still work. Didn't always listen to him
Vibration
Hit your finger with a hammer?
Teardown and Rebuild
My Dad used to drive Ford(cummins powered) school buses. The schools mechanic always told the drivers " if it's too cold to go outside with no clothes on, plug those buses in"
Do you have it plugged in when above 15degrees
brake problems
To test booster, push on brake pedal, then start engine. Brake pedal should go down when vacuum builds.
Block Heater buzz...
I had an open in the cord on my 12 valve at one time. Went to napa and they had an identical cord. Good as new!
4wd actuator bit the dust
Seems to me 2 whl low would be real handy when you need to back a trailer precisely, especially at night. I use 4lo quite often as I must back my trailer uphill on grass between 2 other vehicles. Was wondering if I could use air switch off of big truck to splice into vacuum lines, since my actuator is still good. I think pac brake makes something like this. About same cost as posi lock iirc.
Happy Birthday!!!!!!!!!!
Happy Birthday Mike! Time flies when you're having fun, doesn't it!
2007 5.9 Fuel Pump Fuse or Relay Location
Dust? That doesn't sound good!
Big Line Kit
what is a breather bottle?
Couldn't purchaser build his own extension cable for overhead?
Misery loves company. 365 days of model a ford
As a kid I learned to drive flatheads. The first I remember was a early 50s Jeep pickup. I think I was 5. Nearly every chance us kids got we drove something. Usually late 40s Ford or International pkps. Also had a late 40s Jeep CJ2A. My Dad was foreman on a farm/ranch. Also drove old open tractors quite a bit. Not as old as what your talking about. My dad had a 37 Ford pkp that he put an 85 hp flathead and hydraulic brakes into(originally had cable brakes). I still have the 37, hope to restore someday. Sorry to go so long, just reminiscing....
inspect your parts before installing them
I was impressed because I thought they were just sending you a replacement. Too bad you gotta pay twice.
What Soldering Station?
Are you gonna try it out on those rings?
