Everything posted by Royal Squire
cold mornings fuel gelling
I'm just suggesting when it's 5* or below plugging it in might be wise. Warm when you start that way.
What about plugging it in overnite
Snow Plow?
Even some highway depts. use electric controls.
Snow Plow?
What???
Teardown and Rebuild
Looking good. I didn't see where you got the bumper. I would like to do this someday. Have already had one glancing deer hit. I have a plow so bumper needs to fit pretty close like original.
Can I come over and play?
Turbo Questions
I can hear the cows just fine!
Turbo Questions
Kinda sounds like your just a little apprehensive about diving into this. I was too. You can probably find a video on turbo rebuild. In fact you could probably do a video for this site. Don't know about that for sure, gotta ask someone smarter than me!
Turbo Questions
You can download Cummins turbo rebuild manual and I believe at least one of the vendors on the site here have a Cummins rebuild kit. When I did mine I needed to replace waste gate housing gasket as it was leaking. I also replaced turbo to manifold gasket. Not too tough. You can do it.
Starter Bolt missing, stranded with loose starter
My 12 valve ran for a while with loose bolts and lost one. I just put a longer bolt in the hole that goes through. Seemed to be enough extra threads to hold. Never came loose again but tightened bolts myself this time!!
P0113/P0382 Truck Won't Start IAT and Heater Grid Codes
Dropped the starter on my 2000 and was a piece of cake.
Random ABS light and weird braking performance
That seems kinda random!
Heater Core replacement
I haven't done it myself, but in talking to the po of my 2000, he broke the dash when changing out the heater core, so might be careful of that.
Quadzilla is Back??!!!
Thanks for the input guys
Any reason to avoid a quadzilla. I was leaning towards an edge comp maybe someday, so I've got time to plan. Need other things first. What are pros and cons of both
Transmission Oil Cooler Line Replacement
Sounds to me like you only want to replace the rubber hose. On my 98 there was a quick coupler on the end of the steel line but the rubber hose was clamped on the other end. I just slid hose over the end of the steel and clamped it. No more leaks.
No need to replace it I guess!!
And he said, Let there be Light!
Do you use the extra hole for hb wires?
One Piece Driveshaft from driveshaftspecialist.com/
Used to have a Ford van with an aluminum ds. Amazing how light it was. Took great care changing u joints. I work in crude trucking. Transferred down here 2 years ago from southeastern Wyoming.
Is that driveshaft aluminum?
I hate it when that happens!
Thoughts on Edge EZ vs Superchips Flashpaq vs Other Econo Tuners
I took the end cover of my edge ez, and while it looks like it is well sealed from the outside, I could tell there had been moisture inside. I would vote for some sort of box.
My fellow wood burners!
Thanks for the info. Will try the small fan idea.
Where are you finding pellets for $199/ton? We pay 250-260! Would like to have a forced-air furnace to help circulate heat throughout house, but only suplimental heat we have is portable electric. Stove is Quadrafire Mt Vernon(porcelain coated cast iron). Options are limited since we rent. Sure don't miss cutting wood!
Anybody ever melt the dust covers on shocks? Or, do I need to embrace stacks?
My sons would have the bill on that cap rolled before you can say "you might be a redneck"
