Everything posted by Royal Squire
For us the woodpeckers haven't been as bothersome this year. Not sure why, maybe their aversion to 22 magnum birdshot.
Is that a woodpecker nest?
Weight of empty fuel tank?
Ratchet straps work pretty well with 1/2 tank
Another battery thread.....
If cranking slower than normal, might be your starter
Paint
Might look better to do a contrasting color from body line down, black or gray etc
Fuel tank and In-tank pump vs engine mounted lift pump help
You can rent a test gauge from parts store
Need to check fuel pressure with a gauge to find out what you really have.
47re transplant
Might check with Dynamic. He is a vendor here on the site.
Tie Rod Ends Stuck! 1999 Dodge Ram HD Steering
My dad had a 5/8" gear reduction drill that ran very slow and had lots of power. Used it to mix 5 gallons of paint and drill post holes. Stuck tamping bar through "D" handle and 2 guys hang on
I have a portable gas powered air compressor that is heavy enough that it's really not that portable. Recently was trying to dig a post hole by hand but the area I wanted the post in was pretty rocky. I fought with a bar for a while but then drug the compressor and my CP air hammer to the hole. Lying on my belly I reached down in the hole and broke up the rocks with that air hammer. Worked pretty good. Sorry to high jack thread
Use two large hammers. Hold one solid against one side of the knuckle(the hole that tie rod goes into) and whack the other side with the 2nd hammer. You can alternate hitting around the circumference of the hole. If you can get a good swing on it this will usually break them loose. Hope this makes sense to you. Good luck
Threar locker..what type if any?
What I used most recently is some fel-pro with ptfe that I've had for probably 20 years I had forgotten about. Worked just fine.
Probably be dried up next time I wanted to use it. I can spend the $50 somewhere else
That loctite 545 is crazy expensive!
First Time Death Wobble
How is shimmy different than death wobble?
4th Gen. Alloy Wheel Refurbishment
Is "sick" a positive term??
Wifes Oven Door Glass
Just had to recall the little jingle, then it all comes back Too bad I can't seem to recall important stuff
Jane?
The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
I agree
I agree
I'd really like to have one of these switches but after talking to the local dodge dealer about enabling the high idle, at first they didn't know what I was talking about, then after looking up the tsb, informed me it was only for auto transmissions. They did tell me they could check my vin # to see if it was even possible on a manual. There are a lot of 24 valve trucks around here and it seems strange this dealership has never heard of enabling the high idle. I've been hesitant to return. Thanks for the opportunity to vent.
RV275s
My son had a 96 manual dually and he took on all comers. Of course he went through a lot of tires and if I remember correctly 4 clutches and transmissions!! A lot of fun until you gotta write the checks.
APPS low voltage p0122
I have occasionally experienced a dead pedal and cel with p0122 code ever since I bought this truck, so today I finally decided to order a timbo apps. Afraid it will quit completely out in the middle of nowhere.
Dash and HVAC Box
Man that dash really looks great!
Well this happend on the freeway today...
They must be a real pain, cause I've hit my thumb with a hammer!!
