BBHD
Everything posted by BBHD
  1. 1st snow today in Albuquerque http://http://i882.photobucket.com/albums/ac21/BBHD69/Mobile Uploads/image_zpsk4utrtxa.jpg http://http://i882.photobucket.com/albums/ac21/BBHD69/Mobile Uploads/image_zpssf8yltks.jpg
  2. I had very similar symptoms on my old d-max. it was a failed fuel pressure relief valve that would bleed all pressure to return to the tank. I replaced it with a plug and solved my issue.
  3. Welcome! ABS pulsing? Does it stop smooth? Idk just throwing it out there.
  4. I've used #8 steel shot in gocart tires when I was racing back in the day
  5. Bummer! But at least you know what kind of boost your making instead of guessing off a bad gauge. Did you paint your intake horn?
  6. My truck had the intank pump conversion. There was an aluminum block inplace of the block mounted pump and a harness with a relay to power the intank pump. Might be easier to check thank pulling the fuel module
  7. Yes it was! Still trying to catch back up.
  8. First off thank you to everyone for all the insight and advice! I decided to tilt the bed for access to r&r the module. Everything went on and in without a hitch minus the hour or so fighting to get the numb pump out of the sending unit. Sitting at 19 idle and 16 WOT. After a quick test drive and double checking everything was tight and leak free I headed out to the northern part of NM for my mulie hunt
  9. Alright everything seemed to go through. I didn't have any problems at all with the store!
  10. Happy Birthday Bud! Thank you for all your hard work and dedication!
  11. The engine hoist sounds like the ticket
  12. The brown truck dropped off some goodies today! FASS Titanium 150, draw straw 5 and a big line kit filter to vp44. Hopefully get them installed early next week.
  13. BBHD replied to BBHD's topic in Introductions
    Thank you Nick! You helped me get my account set-up in July and so glad I did
  14. Ive read about tilting the bed and seriously going to give it a go. At this point with 3/4 of a tank of fuel I think that may be my best option
  15. Good afternoon! I figured I officially say hello. I've been a sponge for a couple years absorbing as much as I can from the wealth of knowledge here. Back in April my 99 2500 gave its life to save mine so in May I purchased a 2000 2500 and was finally able to drive it home in September!
  16. Here it goes...first new topic! Well I finally ordered a FASS150 and a draw straw 5 yesterday from DAP! I have a 2000 2500 5speed 4x4 unfortunately with Dodge's intank pump "fix". I'm looking to tap into the wealth of knowledge here to see if anyone has any tips or tricks for the install? Past experience or things anyone may have done differently? Thanks in advance for any advice everyone!
  17. While in mobile view is there a way to switch to the desktop view? I'm probably just missing it. Things are looking great so far. The only hiccup I run into is right after login I get error 1s160/2? I just go to the drop down menu and select forum and can continue navigating. Any advice?
  18. Primarily a mobile user here. Looks great so far. Probably take a little time getting used to the new format. Time to take a look at the desktop mode now!
  19. That shouldn't be a problem I'm sure I can come up with something clean. Approximately how much space is needed for the board? Never mind just read your next post
  20. I'm thinking of installing mine in place of my non-existent cig plug
  21. Sounds like the mag-chloride colorado uses...nasty stuff!
  22. Thank you! I'm enjoining following your build. Awesome job!
  23. I may have missed it but what spray liner kit did you use? Thanks in advance
