Everything posted by Evan
Starter contact wear.
I think time in general causes failures we cummins guys at times are picky most everything works right up until it doesn't any more
Giving the jeep some tlc.
Coilovers in. Now she's screams on rough two track trails put tge pedal down. She's becoming known as a utv killer. 45mp. These shocks are valved for my rig front end weight tire size, suspension geometry and etc kind of terrain I run ohh and valved with lack of sway bars in mind. One of the best mods I've done so far. Also sitting on 35s now Learning alot on suspension and steering talking to lots of shock builders and shops that do rock buggies jeeps and stuff. Geometry is Geometry. Some if this may blend over to the dodge. Been on the trails alot. Looking for hot springs to. Really liking this offroad stuff and meating some pretty cool like minded people
I've been doing jeep cables with a harbor freight hydraulic crimper. Works great. Husky auto electric guy ive known most all my life says no to solder. Autozone starter is in truck cranks fast. Kept my Denson. Also this tool roll is badass been using it at work and in the jeep. Atlas46.com has badass rolls too. This ones by stepp22. Thanks guys for the help. I didnt want to believe it was the starter. Lol
Ok. Ill take it apart tonight. Don't really need it right now but do need to go to Mackay in a week or so. Thanks for the tips
Thanks for the replies guys.. Regardless im going to do cables,, voltage is good to the starter.. 14 while being jumped.. just a click. Whats a good brand.
Is this enough wear to cause a no start. Getting just a click. With starter and jumping passed relay. I think these are larrybs contacts about 8 years on them. Thinking ill put this back together and chase voltage cable issues. Both batteries new two weeks ago. I havent done cables ever so I guess it might be time for terminals and cable's ill build them Was hoping to just have worn contacts but I dont think thats causing my problem. Had a slow cranking issue paired with a fuel leak for awhile and kinda letting it go cause I don't drive it much lately Starter is factory starter from 02
Gen 3 track bar conversion
If you could hold a blum bob through the ball joints. String going through each at the center. Thats castor at zero. Lower ball joint forward is positive castor good driving characteristics. Lower ball joint to the rear is negative castor and shitty driving characteristics
need help deciding on a turbo
Edit 62/68/12
Everyone post a picture of your truck!
Possible Game Changer for lighting our trucks $211
So my housings are now terribly moisture filled thinking about drilling a hole so air can get out. 1/2" or so.
Stock broken and grungy thats what they look like lol
It doesn't look hard to re pin the truck side. But yes bulbs are fixed in less I cut theyre wire and swap thd wires around before the plug or wire a new plug on. Here's a vid. After a quick drive im liking how I have them adjusted Mike will point out the dark spot on drivers side. I did play with bulb depth tonight they seem to work best shoved as deep in the housing as theyl go. Haven't had any one flash me yet. You'd think all this light talk would make me get my cab lights all going. Damn things.
Morimotor told me to run the lights upside down. That was it im done washed. Im emailing gtr now to see wich way the ultra is wired 9004 or 9007. I do like the 2stroke 3.0 unreal light improvement compared to the stockish bulbs. I have walked about 200yds away from the truck and don't feel they blind me. Less so than alot cars that blind me with theyre bright as **** whatever lights theyre running. I've also come to realize photos and words of lights can't be trusted from the internet. Going off mikes or anyone else photos I couldn't say wether the 2stroke is way worse or close or ho-hum. But every one always loves what they run. I would say if a person is willing to repin or run these upside down that these are a very substantial improvement over stock. If it wasn't for these issues I'd love them. Im liking these lights but have a bad taste for morimoto part of it was due to being all email but I didn't feel I ever talked to someone that eats breaths sleeps light. Mike needs to have theyre emails forwarded to him. He'd do a much better job and might convert a few who may be on the led hid fence. Made a few adjustments on driver side and punched passenger a few times. Got them realigned better after flipping bulbs to propper orientation. Might go for a drive and see if I can tell a difference
Looks like your beams are angled in. / \
I do believe them to be awesome but I can't say the same for morimoto or the retrofit source neither very helpful or informative Only reason I went morimoto was because I got on the damn mike bandwagon instead of doing my own research. That got me badass upside down lights. But now we know. The 2stroke beam is far better than the sv4 my freind has them There cannot be one replacement bulb for 9004 and 9007
I'd been running it reversed in upside position. Just flipped it to its correct orientation. Cutt off is better now. Is probly livable in upside down orientation
So morimoto is semi helpful but not realy. On my own I figured out what was stated above. 9007 9004 are reversed high low beam. The 2stroke 3.0 is listed as a 9004/9007 bulb the bulb is wired as a 9007 wich is reversed hi low in a truck with 9004. Make sense? I believe someone mentions earlier. These bulbs are not symmetrical too to bottom morimoto has now said to rotate the bulb 180 to correct reversed high low. I said that bulb is designed to run upside down. Morimoto seems to give information but only when I dig myself and confront them with the info. I notice the gtr ultra bulb is also a 9094/9007 replacement bulb so its also likely to also be reversed The sv4 is sold as 9004 or 9007 not as a single bulb to replace either the sv4 is also a upper led bulb contender Im currently am running the bulb as it should be wich means my hi low is reversed. Thinking on repinning my headlight plug to correct it. Im also wondering about sport Im now thinking about ordering sport housing and a second set of bulbs along with a bright box. 9007 might be correct in the sport high spot
Haha lol true that. I to dont care to follow anything the government says to follow either. I've emailed the retrofit source asking if I can return these bulbs. Doing some more research and more names are popping up of good led bulbs. Driving in a snow storm. Outside temp was about 32deg. I'd imagine these ice over pretty good if outside Temps much lower.
So my bulbs are upside down. I only know from looking at pictures of morimoto bulbs. I've sent morimoto a email asking if they're upside down. Prior to that I sent them an email asking about what lense housing would be best suited to the 2stroke bulbs. Got the same response back saying they don't fit. I think ill be boxing these up and sending them back. I feel like I shouldn't have to deal with this they won't fit bullshit. They're a god damn 9007 plug and play replacement bulb. Maybe the jokes on me but . Im going to see if I can send these back. Get my refund wash myself of morimoto and tge retrofit fit source all together. The 2stroke bulb does seem promising but I just don't think theyre for me. Specially since I have to swap hig and low beams in the truck plug.
I thought silver star halogen bulbs were an upgrade. Gtr seems to have been in the led game for awhile while mormito is old school hid Looks like theres a few plug n play drastic light upgrades for less than 250.
Lol nothing wrong with that. Not sure why bulbs wouldn't fit unless aftermarket takes different than 9006/4 bulbs. The response rubbed me wrong and had nothing to do with question I asked. Guess I shouldn't judge so quickly and harsh. Did you guys see these. https://www.gtrlighting.com/gtr-lighting-ultra-2-led-bulbs-9006 Theres more options out than I realized. Hid and halogens mist like will soon go away ounce led becomes legal and technology catches up.
I think reply came from Indonesia or China. That was my one and only purchase. Not even worth a response to they're reply
