Everything posted by Evan
Suggestions for injectors, turbo, head gasket.
Syco Did you get this thing running cooler?
Belt Tensioner Life Span
I like the cummins Chirotherapie. Mine actually stopped chirping a year or two ago. I think we I put a alternator on. Tensioner has never been changed. 350k now
True HX35
Not sure why these guys think your boost numbers are off. Far as I can tell your fueled like stock. I doubt the smarty will increase much at all. If injectors are realy old they will also contribute to low psi.
need help deciding on a turbo
That power driven vid Was cool to watch. I really like my 62 for All around driving towing
Track bar solutions
I dont know what average is. Thats about how long moog, and oem bars last on our 07. At one point in time i was on bored with the luke stuff. But honestly no one runs that stuff, its super easy just put a new fast food track bar on every few years. On my 02 im running a 7/8" heim track bar. I absolutely despise a tie rod end on the frame side. I cut the factory stuff off my frame and fabbed the frame side from scratch. I have lots of hours into fabbing the frame side id probly be ahead just to swap it out every couple years with a moog or whatever.
Expensive mistake
You had me worried you had a meltdown
Track bar solutions
I wouldn't mess with the lukes stuff. Just get whatever bar the parts house stocks and expect it to last 10-20k
Another NV4500 failure.
Yup a wet fluid changed every 20k or so will make them go long. Thf1000 would be my pick
Purdy. Yeah were gona break 500 on the 07 by Christmas. It hasn't had any transmission work. Just a few clutches maybe at its low power and lowering level the transmission will outlast the truck. I have been impressed with the reliability of my 47re after throwing parts at it 8 or so years ago. Not sure if its cost to build versus some manual trans parts is better not. Just in clutches the 07 is nearing what i spent on the 47
Quadzilla Adrenaline with iQuadBT from DAP
What exactly do you mean by launch timing? I picture a brake stand and launching with 30 psi. 400miles at half tank means im getting good mpg but no where near 28. Its common for my truck but doesnt seem to mean ive burned 15 gallons or 17.
Thats scarey, sposed to last forever
Horsepower and torque numbers?
So tourge is 2.4xhp
So mike. Say you get 28mpg 375hp what is your tourge guestimate. To keep things simple lets elimate things exstending passed the rear crank seal.
Giving the jeep some tlc.
Forst time putting the chromoly front shafts to use My watch dog, started feeding it about a week ago. Not super friendly , kinda inviting when i get gome round the corner to my back door and am greated by a hissing hungry badger.
Im feeling for you. I still want to slap these guys. Ughhh. I probly the same look i give it each winter the 3 cylinder high idle works.. its the now wtf is wrong with it look
more abs brake problems
Id look the master cylinder over for a leak. Seems mine leaked alittle before it leaked alot. On of, on of, on I think you can cycle your key 3 times on the 3rd leave it on it might flash codes across the odometer display
New DAP 100HP SAC 7x9 injectors
Ive read lots of threads and still scratching head
Is it actually shutting down at set temp or just idling for a certain amount of time then shutting down
Ive become curious. Im going to see what idle temp is with motor at operating temp. Will compare turbo to manifold. 200 has to be at or close to minimum at egt probe. Im sure its slighter higher in the combustion chamber, as its cooled since fire. Nothing wrong with a cool down idle
Nowcwhat about SAC compared to VCO SAC slightly more smoke more performance orientated compared to vco. Im probably going to replace my 7×009 sac with sac 7x010 150 or 175 wichever DAP sends. I've got over 100k on my 009s and its time
I was wondering why you aren't doing the build builds rebuild yourself. Ive been wondering where dynamic is and if hes doing all stuff in house or still sending stuff across the world.
When does the turbo timer let it shutdown. I can go from 1000 to cooled off and not registering on my egt gauge in 30 seconds. The hy35 could go 1400 to under 400 quickly to. I never under stood the turbo timer thing. I cant see any truck idling hot. I could see hot bearings but the egt gauge isnt realy measuring turbo bearing temp since its reading exhaust temp ahead of the turbo. I think the turbo timer thing was marketing against the smarty from 12 years ago when everyone ran 50-75 injectors stock turbos and popular smarty Syco Sorry i keep getting off topic. Mike is very intune with the smarty i mean quad. I think it might be best to just have him do a few tunes. I think theres also tune files on here somewhere. Im slightly intrested in quad someday. Used to have the app on my phone. Not sure id ever have the patience to tune it. Id just want to set the fuel to kill and run it roaling coal like a freight train Have you ran any of its default tunes can you tweak programming from these preset tunes? Is that turbo from DAP?
Do you have brake lights? I see your truck has 340k on it. Id just go ahead and change mastercylinder. Calipers proportioning valve danged near everything in the system could be culprit. I did a master cylinder at 300 when my brakes quit when temps dropped below zero. I also wouldn't discount power steering and vacumn pump. Everyone says they don't effect brakes but ive learned different. Id assume at 340 youve doneca vacumn pump seal and probably power steering pump but maybe not. I did vacumn seal but didnt do steering pump. Now im adding fluud to my steering pump a couple times a week if i drive much. I can now feel the steering wheel in the brake peddle when pumpnis low brakes definitely have a different feel. Vacumn pump seal, power steering pump, master cylinder. Consumables that dont last forever. I was silly not to change steering pump when i had it apart.
1977 Ford F-250 Blue Top
Very nice. Whats the story on your old ford. Looks like a solid build platform
- Bronco exhaust
