IBMobile
Staff
Everything posted by IBMobile
  1. It is a .45. I have a 1911 and you've shot it at the Bridgeport range. It pack a punch but I find it a little to heavy to carry around.
  2. What year is your truck. Early 2ed gens may have a wire harness that looks like this at the alternator. Best to ohm test that wire to see if it is a ground or volt test if it power.
  3. I've seen @JAG1party. By 9PM you can stick a fork in him; his done.
  4. DANGER BE ON THE LOOKOUT FOR Beaver Creek PD Use extreme caution if approached Known to cause emotional pain Can drain bank accounts over night
  5. Yes, a 4oz bottle should do it.
  6. I kept mine in because the Boss Lady doesn't want to here it ; says it's loud enough in the cab.
  7. I had replaced my crank sensor. I picked it up at O'Reillys. About a year later it coded again for the sensor. O'Reillys has a life time warranty on it so free to me. That was in May 2018 about 21K miles.
  8. Don't do it! You got what you paid for.
  9. Here is one place that has the OEM intake air hose. part number 53030294 https://store.mopar.com/2002-dodge-ram_3500-base-diesel_5.9_6-transmission_automatic_4-engine-air_intake-duct_53030294-item/ Other web sites are listing it as discontinued.
  10. Electrical gremlins are very elusive but can be very damaging. I've only seen one once when I quickly opened a hood. It was there one second and gone the next; never there long enough to pin down or be photographed. A police sketch artist drew this from my description. He said that he had heard of them but had no idea it was such a hideous creature.
  11. Happy that it did the trick for you. Looking forward to the pics.
  12. You're not the only one. With so much info flowing through different media; is the information true, false, pro-conspiracy, anti-conspiracy, for the good of mankind, for the control of mankind? I think we'll know more in four years after two years with President Kamala Harris.
  13. Now if those electrical gremlins don't stick their heads up for a while it will be great. So what steps did you do and which one do you think fixed it?
  14. I've made an appointment for you.
  15. Coroplast has an out door life up to 2 years and indoor of 10 years..
  16. In the future we won't have to worry about getting ammo. Biden and his clowns from the swamp are going to push for a national registration of ALL guns, then make most of them illegal to own and confiscate them. You'll be lucky if you're left with single shot .22 or 20gauge shot gun. Remember, a gun with no ammo is a club.
  17. Remove the kick panel from under the steering column and reach around the left center support.
  18. That would be a short run for the wires, A 18-16 gauge wire would work fine.
  19. You're having problems with the PCM. The PCM grounds terminal 85 of the ASD relay, supplies the info for the fuel and temp gauges, and controls the voltage out put of the alternator. To start with, check the two ground wires coming out of the PCM for continuity to the right side battery. They are both black with tan stripe wires in PCM connector C3 pin #31 and #32 You may want to repair all the splices the factory put in those ground wires in conjunction with doing the WT repair. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/pcm-ground-splice-repair-r675/
  20. They are different. 2WD part# 55351114AE 4WD part #55351113AE
  21. Where are you going to mount it? You can get the power for the lights by splicing into the orange for the ash tray light or at the radio. For constant battery power splice into the red/tan wire at the back of the power outlet and for switched battery power splice into the red/orange wire at the cigar lighter.
  22. How come there are no Senate hearings on this and where's PETA; this is an outrage! Take that $1,000 and get a cancealed carry permit and a pistol of your choice. Better to be tried by 12 then carried by six.
  23. Like the frog in a pot of slowly heating water the government over time created these departments, agencies, and commissions to 'make life better for us'. To name a few: DOE...Department of Energy DOC...Department of Commerce DOI...Department of the Interior EPA...Environmental Protection Agency FERC...Federal Energy Regulatory Commission TYTDA...Tax You to Death Agency
  24. Here in the US every state has their own inspection policy for which and how often vehicles are tested as well as the minimum passing standards and testing protocols. Here in California emission testing interval is controlled by the postal zip code the vehicle is registered in. If the zip code is in an urban area then emission testing is required every 2 years; if in a rural area then only when vehicle is sold. There is no vehicle safety inspection required here in CA but other states due. So, here in CA we can drive smog free cars with bald tires and bad ball joints.
