JAG1
Staff
Everything posted by JAG1
  1. He he he, good one. Thanks.
  2. If anyone deserves a derogatory name it would be me for not posting the tank access mod. Truth is I have a hard time, wife also, figuring out how to post photos. Joe you are welcome anytime to come look see.... it would be much better that way as there are some important details I cannot get to show in the pics.
  3. I would try some clever insulation practices. You might get some great and crazy ideas on that. One thing to consider, Going to those plumbing contractors supply houses are far better than Home Depot for small pipe insulation. Keller supply, for example, sells the real thick stuff. Makes the HD or the Ace hardware stuff look like it's fake by comparison. It comes various sizes, some for large pipe, big enough to make a 'cupholder' type covers for the filters. For the money.... $450 is kind' high, I would try isulating first anyway. No one can tell but, this winter might be a real puncher.
  4. Might be good to insulate the fuel lines with the smaller pipe insulation. I would try to get some insulation around the filters too. It might help. I use the foam pads they use for sleeping on the ground . Cut a pieces to fold over the bottom and go up around the sides and zip tie it. You can get real creative with that stuff for rv doors and many other areas.
  5. Is it an easy change out? From under the hood and not have to remove the dash? Wondering too if there is an easy way to lube the shaft bearing?
  6. Thank you for the complement LiveOak. I think most buyers would rather not deal with the county, septic permits, well drilling, power company and land use zoning and water rights etc. Lots of folks would rather have those things taken care of. There is less risk anyway.
  7. interesting story about bee keeping, getting a new wild hive. I did not know that you can buy buckets of pollen to feed the bees during winter months. Do you Just spread the pollen on a flat surface and they come gather it?
  8. Freezing rain/ sleet, 29 degrees, east wind gusts to around 20 mph. Woodstove hot, burning maple.
  9. Around the freezing mark here this morning, in western Oregon, with the wind howling around 40-50 mph gusts.
  10. Wow! How about if you wet your lips do they freeze together? Gotta' hurt. In any case, I see a big need for chapstick. minus 58.... can't imagine working in those conditions. 42 degrees here in Western Oregon this morning.
  11. Can you describe what -30 degrees is like? Do you all pee ice crystals in conditions like that? Not to be funny just really would like to know if that's true. Also if you carry out a cup of hot coffee in a mug does the coffee mug crack and break too?
  12. I try using the overhead for comparisons only bu,t know in reality, like you say, a marketing stint.
  13. Living less than a hundred miles from the coast those conditions would be like the worse portion of our winters here in Oregon. I feel for you guys because I know it will get worse as winter progresses for you out there.
  14. I'm watching for decreased fuel economy, white smoke, rough idle, and any other notable signs. None so far. It's very weird since fuel econ. has gotten better, not hand calculated, just what's on the overhead computer. Weird because I've never had such great fuel mileage like I have lately.
  15. Yes, when the dead pedal occurred. Codes where 500 from laying scratch on my gravel and 0216 for about 3 years now without any symptoms other than momentary fuel cavitation. Next mod is the Hellman tank sump with a swing away skid plate to stop the cavatation.
  16. I was just reading some forecasts on this, one reputable forecaster said Arctic blast will be of 'historic proportions' in that it comes so unusually early and with the way conditions are setting up. Doesn't happen very often. Last comparison to this time was back in 1955.
  17. Those are the 3 things I read about on other forums. It's not like I'm so experienced that l know how to solve all problems. Basically shootin in the dark tryin' to avoid the 44 is the truth of the matter.
  18. I understand there are 3 other items that cause hard starts. Bad or intermittent ASD relay. Bad or intermittent fuel shut off relay. Bad overflow Valve. Assuming everything else in good order.
  19. I got momentary dead pedal on very very slow take off when cold. So I put on the Timbo Apps with no dead spots afterward. Howver, I got one hard start when the engine was still hot. How long did you guys run your old VP after hard starts? Thank you in advance.
  20. PICTURES..... ENJOY.... There is no proper arrangement to the pics, all taken from this same valley. At least you can see the rock I spoke about in a couple different pics. Barely see the Bristlecone pines on top. I have a couple shots from on top of the rock in which there are a couple 1,000 yr olds. See if I can post those tonight.
  21. Sorry to say that my wife came home sick tonight with flu like symptoms so no pics tonight. I there someone willing to explain the picture posting process? I will try if there are no technical terms but explained very simply. Killer, how far away from a bear does the smell become so pungent? It was very strong and sudden. Also I had a bull Elk charge at me once while staring too long at his females. He stopped charging for me when I fell over a stump while running. I did not smell anything like the smell I experienced this day in the Sierras.
  22. I know that smell your talking about, when you cross an area of a bog with stagnant water and rotting organic material. I know it wasn't that as I would have recognized it. I was beyond the wet area and above the spring on the V shaped hill by then. The wind was blowing a light breeze as if the warm air helped cook up the scent of pines. The smell was sudden, overpowering. Something I had never smelled before but was unmistakably that of a wild animal, as if nature designed a perfect warning signal tuned for human interpretation, something innate that warned you to turn away from there. I want to post the pics soon.... it bugs me I have to have someone do it for me all the time. Although they are on the computer desktop at least. Wife will have time early evening to post pictures. I know you guys would like to see this place.
  23. The smell wasn't something that creeps up on you slow and recognize later. This was a sudden radical change from smell of the Ponderosa Pine in the air. It was very potent and unmistakably wild whatever it was. Even though I had never smelled anything like it before it was as an immediate warning to stay away.
  24. I went to visit my elderly mother who lives at the foot of the eastern Sierra mountains. I try to get down there often, from Oregon, because we don't know how long she will be with us. One fine day I decided to go hike up into a canyon valley. It's an area of great beauty because of the meadow and the high saw tooth ridge tops all around. Going quite a long way up this valley it becomes a very large canyon with huge walls of granite growing ever closer together. I then discovered a huge granite rock in the middle of the canyon about the size of 5 football fields and about 200 foot high. The oldest living organism on earth was growing out of the rock crevices on top of this rock., the Bristlecone pine tree . It's seemed as though this big rock tried to be a mountain in geologic history but, didn't quit make it. I decided to go around the back side to see if I could go around it. There where no trails but was an easy walk since it was like an extension of the meadow below all around it. Only it now has become a forested meadow with some enormous ponderosa trees in amongst all the other trees, some with an 8 foot girth. Their branches alone looked like tree trunks. As I walked around the big rock I saw strange and varying rock formations by way of how they broke apart or weathered over time, but were in groups or families in how they were shaped all being somewhat the same in each group. Some looked like varying sizes of pillows, some were fractured in huge curved plates as if you could choose one for using as large rain water basin. Some were smaller like you could prepare a meal on. Others were flat like for stepping stones but too large to lug anywhere. As I continued around I began to notice how pristine everything was. Untouched, as if I was invading a very special place. A place where one is not to go, does not belong. It was a strange feeling, but certain I was yet to discover something great, I continued on. You all know how dry the eastern Sierras typically are but this year in particular is in major drought conditions Something like the worse ever according to record. Only now I discovered a small area of very green grass that was very tall but all matted down like some kind of animals are bedding down there. The matted area was very large, too large for just a few animals. As I looked around for a source of moisture uphill from there, I noticed above this area was a spring that over time had worn a large V shaped depression in the ground that would be protected from wind and cold. What a great spot for a herd to stop and bed overnight, I thought. I continued further on above this spring, going further away from the big rock but was now on the backside. The ground was gently sloped but I had an even stronger, uneasy feeling that I did not belong there, like I was trespassing inside a territory one was not to go. Immediately I smelled a foul smell, not like animal droppings or dead animal, nor a skunk smell but, as if it were the smell of some kind of beast. It was like the foul smells that expert animal behaviorists report that you should stay away from. I never smelled anything like it before but I knew it was from something alive. It was as if it was warning me with it's particular gland that emits this foul order. At this point I took the warning and turned around toward the big rock again to continue going all around it as planned. I got out of that area and closer to the big rock again with a somewhat uneasy feeling about that smell but felt the rock was somewhat more my territory by then.. I headed thru more of the forested easy walk that would now be about the half way point around the rock and happened on a small meadow. I then looked up over the rock between the Bristlecone pines and saw the most beautiful wild, pristine view of my life. It was a true blessing as another saw toothed ridge of mountains appeared behind the already inspiring canyon walls. It instilled as sense of wildness, an untouched world as it was meant to be. It was a very rare sight and created in me a very rare inspiration unparalleled through my whole life. I got pics that I will post soon, but, none with Bigfoot or whoever, whatever it was. BTW, hunters, what was that smell, or what could it be? I know it's Halloween but be honest K? Mike
  25. It would be cool if they had a piece of pipe inside the existing pipe that slides easily up and down to clean the chimney. It would be on a chain and pulley so you just go outside and reach up near the gutter/ eave and pull till it's cleaned again.
