c farmer
Everything posted by c farmer
  1. Yup a snap ring. If I remember right, in the over drive unit.
  2. It doesn't really matter, if your pulling the box replace both of them.
  3. I have a skid steer and a Polaris ranger. I would rather plow with the ranger. Works great.
  4. So my lope is a miss fire?
  5. What causes this? I get it a lot sometimes and none other times.
  6. Thanks, I really liked the TST box that I had.
  7. I haven't checked. I will tomorrow.
  8. I have a 02 6 SPD. Has 150hp injectors and boost elbow. Truck runs great but once it hits about 30 psi boost it stops adding fuel, just like a light switch. Do I need a boost fooler? I had a tst at one time and don't remember my truck doing this. Thanks Adam
  9. I use power service all winter, maybe I should start running 2 stroke oil to?
  10. Where at in central pa? I am near state college.
  11. Take the pitman off and move it. I think it will go on 4 different spots.Sent from my DROID3 using Tapatalk 2
  12. You have a tst too. I have a 351vgt I am getting the parts for.
  13. I use a 6637 filter too. Seems to work great.. Willm, the bracket looks like it works.
  14. Yea the 47 and 48 trans seem to go in to overdrive and lock up pretty quick. Dont know of any way to adjust it without affecting all of the shifts.
  15. 3 cylinder idle doesnt sound good. But it works.
  16. I have a 02 and black lettering on the valve cover. Hope I am good. Just something esle to fix IF I have to.
  17. I would be afraid of locking the ecm, be careful. I am super afraid of trying a programmer.
  18. It can't come out of the shifter hole unless you rolled the trans over.Sent from my DROID3 using Tapatalk 2
  19. My truck is rusty and stock looking. Nobody wants to see that. LolSent from my DROID3 using Tapatalk 2
  20. I have a Valair dd organic clutch and love it for towing. A little jerky once in a while and noisy. But it holds great.Sent from my DROID3 using Tapatalk 2
  21. I want one. I already have a 6 speed. :)Sent from my DROID3 using Tapatalk 2
  22. I wouldn't do it on a dimmer switch. Your fan would run a what ever speed your dimmer switch was set at. Might be hard on the motor. Sent from my DROID3 using Tapatalk 2
  23. This is what I am going to do, bought a 4" downpipe and tailpipe. Just need the 4 " pipe. Any idea how long I need. Its a quad cab daully. Sent from my DROID3 using Tapatalk 2
  24. No. Nothing is the same between the cr and vp trucks.Sent from my DROID3 using Tapatalk 2
