inexpensive borescope
so i have this app called "geek" and it has mostly chinese stuff but a lot of it is good quality nicnac stuff.. i did find a borescope for about $8 that plugs into usb and works like a champ lights and all. then i searched for a 5.5mm borescope and they have them (size we need to get into the cylinder through injector hole).
So i figured id let the community know of where to get a fairly good working borescope for engine inspection for cheap!!!
i w et agead and purchased the one in the pic and will do a write up on it.
Mike if its possible to make this a global post so everyone sees it and can use the info please do!
Edited by CUMMINSDIESELPWR
Dang it, I was getting a little excited about this.  Have it strapped to somewhere on the truck, and watch what's happening from in the cab!  My first thoughts were wastegate.
5 hours ago, CUMMINSDIESELPWR said:
these caneras have leds on them and they are usb so a tablet or laptop is needed
You can get a micro USB and that will work directly with your phone.
Then software app called CAMERAFI.
Screen for phone then becomes your screen.
Cursious to see some injector/cylinder pivcs from your setup - maybe its better (hope so).
