- Replies 32
- Views 6k
notlimah 6 posts
leathermaneod 6 posts
Mopar1973Man 4 posts
dripley 3 posts
There is no reason for a 5" unless you like it loud and lots of drone. For most of use that are daily drivers like myself there isn't much of a gain going even to 4" pipe. I'm still very capable of tu
Backpressure is a variable only for naturally aspirated engines because of the reliance on intake velocity, vacuum, and scavenging in order to best the combustion chamber efficiency. Charged engi
The drone will prove to be a problem for just about any aftermarket exhaust system merely because those companies didnt perform all the costly R&D the vehicle manufacture did in order to tune the
So I got 4 inch dp to back of cab then up to a stack I want to put an exaust on it with a muffler the drone is crazy
so opinions on 4 or 5 and diamand eye mbrp farm boy diesel what one I'm up in the air I take the truck on every long trip so it has to be able to sneak under the radar so to speak
all abiding laws aside
