Which fuel pump should I get?
- Replies 35
- Views 11.2k
I agree with both of the above. A gauge is absolutely necessary. I run an AD in mine with filters and still run mine thru the oe filter canister. I like having the water in fuel sensor and fuel heater
Gauges are a must. Whether you have a super-expensive aftermarket pump or the stock pump you need gauges. Expensive pumps fail too and the low pressure light may be too little too late. An actual f
I am running an ADII 165 gph rated pump. I have run it with a Banks 75 hp chip, stock and with the Edge comp. Never had any issues with the fuel. I used this pump mainly in case I ever did anything cr
My 99 QCLB has 315k on it and is on the 3rd lift pump. The previous owner had the fuel pump replaced by the dealer the first time then used a big rig shop's replacement similar to the carter. So far it has been working great. The big rig shop also installed a fuel pressure dummy light which comes on only when with the wait to start is there. One of the banjo fittings on the VP44 is where the dummy light has been installed. Once the truck is running it never has come on. I mostly use the truck for hauling a little 7x12 utility trailer, camping, and pretty much any other excuse I can use to drive it. Reading through the different articles I see the first upgrade I should do is replace the carter style with a FASS or Airdog high flow fuel pump. On the FASS website I see there are 3 options:
Adjustable lift pump 95gph for $436
Direct replacement (no GPH rating just higher flow) for $249
Titanium series with the filters for $597
My future plans for the truck are some sort fuel/timing controller such as the edge or smarty and some ISSPRO gauges. I have seen many setups on here that keep the factory fuel filter and lines, some replace all the lines with 1/2", and some run a pre filter. If you could do it over again, what fuel setup would you choose? I am open to any suggestions. Should I get a fuel pressure gauge and monitor the pressure first? Or replace it then put the gauge on? Is the titanium series with filters worth the extra $ or will a WIX fuel filter in the factory location do what I need?
Thanks
