Quadzilla Adrenaline V2 Testing
TFaoro
6 minutes ago, Me78569 said:
nutso.
I thought the pigtail normally came with the sensor.
My local Cummins dealer is useless, most of time I tell them what I found out and then they can help. When i got my sensor few months back that's all they gave me, never even mentioned this adapter. No I called them and said I need an adapter, they had no clue, I told them what I knew and the guy called me back and said yeap found what you need. End of conversation. Then it was basicly you want it or not, can have it next day for only $30 in freight, or wait till cows come home, and we'll call you. So Genos it was.
2 hours ago, Me78569 said:
Yellow turbo is the turbo timer.  If it is yellow you know the feature is enabled.
Need to change the color of the icon to green or something other than yellow. Yellow tend to pop to mind to being warning message. Where green is just a notification. Danger icon should be in red.
New flash with HUGELY improved wiretap fueling smoothness.  I am unable to feel when wiretap comes on now, also transition smoke is gone.  No more uncontrollable puff of smoke when the psi is reached.
https://www.dropbox.com/s/up9aaaxccu9twph/ADR1000V2.exe?dl=0
Thing to note is the changes to the tuning variables for
Low pump limit psi and low pump %
Low limit controls the same function but is changed in how it works. It is still where wiretap fueling starts.  change is how the fueling is calculated to improve smoothness
Low Pump % is now to set the low limit for the lowest % of wiretap you want once the above is reached.  Most if not all DD tunes should have this set to below %5.  Above that should be race only.
documents have been updated to reflect the change.
Edited by Me78569
  • Like 4
https://www.dropbox.com/s/bczqy1dl92h9x56/ADR1000V2.exe?dl=0
This is a huge update for anyone that wants it to be smooth! Even with my fat injectors I have no puff of smoke when wiretap starts fueling. Honestly you can't even tell other than it smashes you back in your seat. I would highly recommend everyone running V2 download this new one.
Tyler and I were talking about oem timing.   Figured I should do some more data logging of what the ECM is doing in terms of timing.
These show purely oem timing with no quad fueling or timing adjustments.
It appears that RPM play the greatest role in terms of timing, boost does, but not nearly to the degree that rpm does.
IF you want to download the datalogs they are attached.
iQuad-2016-11-18-07.31.031496951642.csv
iQuad-2016-11-18-07.35.531190242772.csv
iQuad-2016-11-18-07.32.481566824965.csv
Edited by Me78569
