Boost leak question
So I did a boost leak test on my 99 cummins found a t clamp that needed to be tighted. Took the tester to 25 psi. The gauge is slowly going down like .5psi every couple second. Did the soapy water test can't find anything. Can't hear anything. Is this normal to loose psi with it pressured up or should it stay at 25psi.
  • 4 weeks later...
Ok so I still think I have boost leak hate to say it. Maybe it's just me, my boost guage ticks or vibrates however you wanna put it the needle is not steady. Might just be me I took a video hopefully you can see it. It's a pretty bad video.
IMG_0690.MOV
Edited by abner99
Yeah it's pretty bad the roads around here are pretty rough. It's like your at 16psi of boost but it wiggles back inforth between 16.5 and 15.5 not a lot I'm  exaggerating like its vibrating.  I changed sending unit that didn't help.
8 hours ago, SilverMoose said:
I just switched from a 1/4" line to a 1/8" (both id) and my boost gauge bounces around at lot now.  Gonna figure out a little oversized expansion chamber to see if that fixes it.  If not a snubber valve.
So you went smaller and it still bounces that weird. My fuel pressure bounces a lot with a needle valve and about a 4 foot 1/8 line plus a isspro snubber. So I don't know I'm gonna try another snubber in there plus a restictor.
How far do you open the needle valve for your fuel pressure gauge.  Like was said above, it doesn't need to be opened much.  Mine is also just barely cracked open, if I open it too much more it will bounce around.
