- Replies 32
- Views 6.8k
notlimah 10 posts
CSM 4 posts
jlbayes 4 posts
CTcummins24V 3 posts
A converter will stall differently depending on load. However, it will fall within a general range. You can think of it as the RPM the converter changes from a turbine that converts a given torque a
quit getting along and understanding each other....this is an internet forum and we have no room for that behavior oh wait... No you guys are good hahah
This isn't bookface.....
Starting a new thread so we don't clutter up other threads with this talk and we can have it in one dedicated thread.
So @jlbayes you're the second person now I've seen post in the last couple days saying that the lower stall speed was terrible. Seems weird that builders like @Dynamic are using the slightly lower stalls, but the end user isn't happy. Is it just a preference on your end or is it actually performing bad? @Dynamic you said that the slightly lower stall speed was good up to around a 62mm sized turbo right? @jlbayes what size charger and stall speed where you running?!
Tagging for sa purposes: @CSM @Silverdodge @Me78569 @JAG1
