02 Cummins 1850rpm max
2 hours ago, Me78569 said:
we need to get this into an article so it is not lost.
Can you do me a favor and post, in one post, all the issues you had with specifiics and the resolution to the issue?  Think of it as a searchable issue and resolution.
 Second that!
I swapped a 02 Cummins that was a manual into a f250 (08) automatic. As I was making the wire harness up, I noticed that the harness I had did not have the vss wire. It had a engine speed sensor.  When I got the truck running with the manual ECM it had a lope so bad that it would die as soon as you put it into gear. So I sent the ECM off to be reprogrammed for an automatic. When I received it back, I put it in and the lope issue was solved but the truck would not go over 1850 rpm's. So as stated before, there was no vss wire hooked to pin 43. So I pinned a wire and that did not help at all. So upon talking with other people, I decided to purchase a PCM and wire it in, because the ECM was not seeing the ground from pin 6  on the PCM, which tells it that it it not in park. So when I received it, I wired it up and now she runs like a dream. Thanks for all that helped and threw things at me to make me think harder!
24 Valve Neutral Safety Ground method.pdf
24V PCM Schematic.pdf
Edited by mossyoak71
Clarify and add schematics
Ok so now I need some help with the tuning. It's an 02 Cummins with the following mods: DDP 125hp injectors,  ARP 425's,  billet oil squirters, SO VP44 pump with BD wire tap, 120# valve springs, DPS 62/65/12 Turbo with a Borg Warner S475 Turbo, FASS 150 titanium, mishimoto intercooler, straight 4" exhaust back to 2- 6.5" stacks. So I am not very familiar with the Cummins tuning, as I have always had Ford. The latest being a 6.oh no. But the Cummins resides in it's spot now. It is mated to a stage 5 automatic 5r110. Would like some help with a daily driver with good manners ( I live in Charleston SC, so stop go traffic). Also need a good Dyno tune for when I go to Rudys Fall Jam. Still learning.
Best bet is to look towards the Quadzilla Adrenaline. It will allow for your large injectors and be able to tune it to be smoke-free for the most part. Allow for custom timing curves for all your needs from daily driving, towing of all-out dyno runs.
https://mopar1973man.com/forum/174-quadzilla-power/
I helped him load up v2 this afternoon.
@mossyoak71 I hate to say it but DDP injectors are a really bad injector to start with.  @jlbayes can tell you what spec the nozzles are, but they are not right for truck application and they make tuning out smoke VERY tough.
As a starting point I would try out my tunes.  They likely won't pull enough fuel to clean up the injectors, but it is a start.    Since you have good supporting mods you can run a fair bit of timing after 2k.  sub 2k our trucks seem to like less than 20* total when on the throttle.  Off the throttle some members such as @Mopar1973Man and @trreed say their trucks like 21-23* of timing at cruise state.
all we really know is that each truck is a little different.
What I have found for power is if you can tune your truck to just enough to go beyond haze into smoke then you will put down peak power.    I am not talking thick smoke, but just beyond haze.    I wouldn't say my truck is any more powerful with a starting % of 105 compared to ~94.  Torque comes on harder at 105, but that is not a good indicator of power.  the old butt dyno hasn't been calibrated recently so it is not trustworthy.
If your butt dyno is calibrated I would find that odd. :shifty:
ok, i know i should start a thread in the quad part, but don't want to bore anyone out there. I'm used to the ford 6.0 tuning and the vgt turbo. so that is all computer controlled. So now i have to put my less than smart hat (stupid for lack of better words) on. The following is what i have been playing around with. It is fairly clean running just takes a little bit to get the turbos to light. So my question is how do you get these turbos to light? I'm assuming that the more fuel you add the more they spool or is there some other way. sorry for the stupid question. I have seen 57lbs of boost so far. Thanks for the help.
Power Levels: 6
Timing
Fuel Load Timing: 1.5
Low PSI Timing Reduct: 2.5
Timing Reduct Scaling: 100
Light Throttle Timing Adv: 3
Light Throttle Timing Load Limit: 15
Timing vs rpm
1500:18
2000: 20
2500: 22
3000: 24
Timing Max: 26
Wiretap
Pump Stretch: 1800
TPS Pump max: 100
TPS Pump Min  20
Minimum Pump Tap Fueling Percentage: 5
Pump Low Boost Scale PSI: 10
Boost Scaling: 35
RPM Limit: 3500
Power Reduction:
0 PSI %: 77
1 PSI %: 78
2 PSI %: 79
3 PSI %: 80
4 PSI %: 81
5 PSI %: 82
6 PSI %: 83
7 PSI %: 84
8 PSI %: 86
9 PSI %: 88
10 PSI %: 90
11 PSI %: 92
12 PSI %: 94
13 PSI %: 97
14 PSI %: 100
15 PSI %: 103
16 PSI %: 106
18 PSI %: 110
20 PSI %: 114
22 PSI %: 118
24 PSI %: 122
26 PSI %: 126
28 PSI %: 130
30 PSI %: 134
7 minutes ago, mossyoak71 said:
Power Levels: 6
Timing
Light Throttle Timing Load Limit: 15 Change to %5 over your cruise state load %
Timing vs rpm
1500:18 Change to 17*
2000: 20
2500: 22 change to 23
3000: 24 change to 27
Timing Max: 26 change to 29
Wiretap
Pump Stretch: 1800
TPS Pump max: 100
TPS Pump Min  20
Boost Scaling: 35 Change 40, this gives more resolution to the map.  Using naything other than 40 should only be done on stock turbo and injector trucks looking ot make a ton of torque.
RPM Limit: 3500
Power Reduction:
0 PSI %: 77
1 PSI %: 78
2 PSI %: 79
3 PSI %: 80
4 PSI %: 81
5 PSI %: 82
6 PSI %: 83
7 PSI %: 84
8 PSI %: 86
9 PSI %: 88
10 PSI %: 90
11 PSI %: 92
12 PSI %: 94
13 PSI %: 97
14 PSI %: 100
15 PSI %: 103
16 PSI %: 106
18 PSI %: 110
20 PSI %: 114
22 PSI %: 118
24 PSI %: 122
26 PSI %: 126
28 PSI %: 130
30 PSI %: 134
Your canbus tuning starting point is VERY low.  I start at %85 with my 7 x .009's at 7000' altitude.   This is an indicator of your injectors being badly suited.  I would expect you to be able to run smoke free at %90 starting point with 125 hp injectors.
As for getting the turbo to light, more fuel.  again the cone angle of the injectors is going to cause smoke issues the more you bring up fuel.
they market well, but there are other builders out there that do better injectors for a fraction of the cost.
DAP, DFI are both builders that have cost effective injectors.
Money no object then Weston or some other guy I can't think of right now.
Well I'm tired of trying to get these DDP injectors to clean up I'm just getting a lot of smoke so I looked at the DAP injectors and was wondering what I was wondering what the difference is in the sac and a vco injectors. Which one should I get was looking at the 125 or the 150s thanks
