Has anybody  figured out why track bar failure occurs?
This will be the 4th or 5th one that I have had to replace in 170k....
The end that attaches to the cross member is quite loose...
If I recall correctly, the last one I  replaced was in 2016 at about 160k .
It is a Quick Steer brand made of "Forged Steel" according to the manf.
Thanks and if You Guys have a recommended unit to buy this time, I am ready to try a different brand.
Ed
PS: I am a much more mellow driver in my advanced age (53) than I used to be!!
  • Replies 34
  • Views 12.4k
  • 01cummins4ever
    01cummins4ever
    I’ve used the Luke’s link that dieselfuture  Posted, I used them on all the joints, installed 6 years ago and have held up well, but track bar joint is due for maintenance, They do come with shim
  • Dieselfuture
    Dieselfuture
    If I may add, front springs settle with time and put pressure on track bar shoving the axle to passenger side. So there is constant pressure on it. In my mind the only cure is to put an adjustable tra
  • RipnRam99
    RipnRam99
    I have a little bit of input on this... I was on my 3rd track bar at 160k on my stock height 99, with 285/70-16 tires.... I have a lot of friends with Dodges around here, and we all go through track b
Tires and size. I ditched the 265's and went to 235's and only replaced 2 track bars in 330k miles. NAPA was my last one was really good lasted over 150k miles. I've got a lifetime Autozone now and I know it will fail soon. No grease zerk. :rolleyes:
I'm 47 so I'm right there with you...
If I may add, front springs settle with time and put pressure on track bar shoving the axle to passenger side. So there is constant pressure on it. In my mind the only cure is to put an adjustable track bar on and periodically keep an eye on it if it needs adjusted. Do you notice how you have to put a jack under the frame and lift it up to get the bolt lined up.
There is also a rebuild kit for the ball joint side that has lifetime warranty so you don't have to change track bar every time especially if it's out of warranty
https://lukeslink.com/about
And the bushing on the bottom side is sold at just about any part store, just make sure you get a poly one.
P.s. I'm still young and stupid
Edited by Dieselfuture
Have an adjustable on the 02, so I'm going with the stock one on the 01 to compare the two.
The 01 just got a new OEM at 200Kmiles.
Posted, I used them on all the joints, installed 6 years ago and have held up well, but track bar joint is due for maintenance, They do come with shims to take up slack, I havnt tried it yet but will do here in the near future, if worse case I can just install a new link. Stil beats paying the big bucks for a new track bar. With that said, I do believe they only work with the factory size bar.
and since were talking age here. I’m still 25 in my mind, but periodically my 51 year old body has to remind me how old I really am.
Any OE or similar style track bar uses what is effectively a tie rod end for the joint at the crossmember. As shown by the factory Dodge steering components (T-style), tie rod ends don't like to be used at an angle with linear loads perpendicular to or in parallel with the axis of the stud. They hold up well enough for steering, but when they have to bear the load of the truck's weight transferring, plus act as a fixed piece for the steering to leverage off of, they don't hold up. The outer housing that's part of the track bar itself will first slide along the axis of the stud, since the relative angle of the bar from joint to joint is more aligned with that axis, and consequently exerts the load on the ball at this angle (not just horizontally). Leveled or lifted suspensions exacerbate this by increasing the angle from horizontal and putting the joint at a more extreme position in its range of motion. Best thing to do is swap it for one that has bushings, Johnny joints, or heim joints at both ends using a conversion bracket. I really like mine from Dodge Off Road, but you can always go with Synergy, BD, etc (though I think they aren't as strong or well-designed). Whatever route you take, always keep front end components well-greased and clean of debris.
I couldn't afford an aftermarket adjustable one at a time, so I made my own with bushings on each end. Been working good so far.
  • 3 weeks later...
4th track bar in 171 k...Biggest tires I have run was 1 set of 285's...
Mostly 265's and the truck has had an easy life...min towing rtc...
Dunno ....
So I guess, being as I'm waiting for the Doc to clear Me to get back to work ($12.00 per hour kinda puts a crimp in the ol budget, but Man am I Glad to get that!!) , what's the consensus as to the best value in a lower-cost track bar?
Edited by DocH
Added content
Score card for me...
2002 Dodge Ram 2500 - 2 track bars in 336k miles.
1996 Dodge Ram 1500 - 0 trackbars in 169k miles.
Both trucks are running 235's for tires. It does make a difference.
I have the original track bar. I've checked the end several times it still seems tight
My trucks whole steering is tight too
I 'baby' my truck though
Edited by GSP7
My 02 is on its 3rd track bar, went on right around 400k or so.
Edited by dripley
My last track bar was a:
 Quick Steer DS1413 Track Bar
 and it was installed in May of 2016...approx 10k ago...and about 6k of the 10 was just interstate driving!!
Hmmm...I can get a ProForged Adjustable thru Amazon for around $100.00...BUT, the reviews I am seeing there are not very encouraging!
Here is the part:
Proforged 106-10044 Greasable E-Coated Track Bar
I hope I'm not getting in trouble here, but I will cut and paste a couple of statements from some folks who Did buy the 100.00 bar:
"had the track bar for 4months and i havent even put 2000 miles on it and i have to tighten the trac bar every other day even after using loctitie"
"I have had this on my dodge truck less than 2000 miles and its wore out and cant figure out how to get product warranty of 100,000 please help
Proforged 106-10044 Greasable E-Coated Track Bar"
You Guys are getting the idea....
Maybe I am just better off getting a ACDelco 46B1127A for 45.88 and call it good.
The local Autozone = 85 + tax for the non-adj bar.
How important is the fact that the bar be Adjustable?
Thoughts?
With time front end sags and frame pushes on track bar which pushes axle to one side and that's what causes faster track bad wear with time. So when you adjust it the idea is to center axle and frame so at normal level condition there is no pressure on track bar only when on uneven ground it will keep axle where it needs to be. In my mind it should of had adjustable bar from factory. No different then doing alignment with adjustable tierods. But you know some ceo had to make more money.
I would probably try that adjustable bar for 100 before partstore one, but Hurd to tell quality from pictures. I'm sure once you get it where you want it couple pipe wrenches wold get it tight enough or a good tack weld.
Another option is to rebuild yours with  https://www.genosgarage.com/product/lukeslink-tbrkit/trackbar-rebuild
I cant argue with what @Dieselfuture says on adjust ability. I have about 20k on my second MOOG non adjustable track bar. The cost was about $100 from Rock Auto. the first one had about 160k on it. Hopefully this one will get the same. Dont know yet. My springs, as best I can tell, have not sagged. At least if they have they have done it equally.
Ok, I got a question, I was Gonna start a new thread, but I saw this about the track bars and thought what the heck. I replaced mine 2 years ago with a moog. The weird part, it was longer than the one I took off? And the steering wheel was way off, I had to adjust it. I went back to orielys and compared another one, it was same size as the moog. Went to Napa, different brand, same size as the moog. Tires don't wear uneven, but now I get water to kick up on passenger side window when it rains?
Edited by Alexio Auditore
Accidentally submitted before I finished typing
Possibly pushed the axle to the passenger side due to the springs sagging. A longer track bar would do the same.
That’s the nice thing about the adjustable track bars. Easily compensated for things like this. Usually a two man job though. One person to push on the truck side to side while the other is under the truck spinning the bar.
14 minutes ago, Alexio Auditore said:
Did dodge have different size track bars? Mines a 2001, is it different than a 99 or 2000??
Cant answer that for sure, but it would seem to  me they should be the same.
