Worth it to go southbend with fairly stock truck (nv5600)
Edited by portlandareae28
Duplicate
  • Replies 36
  • Views 8.2k
  • Sheesh.    Imo, it’s up to the owner to do their own research before purchasing items.  At least be informed.    In this day and age of information at our finger tips there  is zer
  • I'm not sure if the 3rd gen NV5600 clutch and the 2nd gen NV5600 clutch are the same or not, by my OEM clutch held just find with the S-JR on the 40hp setting and towing, but it slipped the first time
  • Mopar1973Man
    Let's say an Edge Comp (5x5) and Smarty (Sw Lvl:9) is enough to slip a stock clutch.
Worth if you stay fairly stock, I would say no if plan to stay that way. South bend makes a great clutch but my oe held up just fine with even with a mild tuner on it. Did some heavy towing with it also. Not alot just moving the 5th wheel from job to job. I would think SB make a lighter duty clutch but never looked for one.The oe clutch lasted 250k in mine.
I still have a non slipping stock clutch and I have had a Edge ez Edge Juice and Qaudzilla ADR and now 75hp injectors and never slipped it yet.
13" disks found in the NV5600's are good to around 60 hp over stock.... And I ruined one with a smarty that was only adding 30 hp at the time.  The reason for the low power rating (~305 hp) is because while the diameter of the clutch increased from 12.25" to 13", the amount of friction material remained the same, reducing actual friction surface area.  As seen above, a couple of us have had good luck with 65 hp tuners and stock clutches. Both @dripley and @Marcus2000monster have the NV5600
It all depends on what you want from the truck.  Stock power?  Edge EZ and 75 hp injectors?  Compounds and 6x0.013's? That all factors in to what clutch will be good for you.
Edited by trreed
Way too many people think there is something special about the NV5600 vs NV4500 the gearing is nearly the same there is only an extra gear down around 25 MPH. Other than that the 6 speed is no different on the highway from the 5 speed. Look at the top two gears. I'm typically in 1.00:1 (Direct Gear) by 30 MPH
So as for the clutch issue if you have a 5 speed and upgrade to South Bend Clutch you'll end up getting a 13 inch flywheel. So stress levels between both transmissions are the same it just a matter of do you have the old 12.25 or the 13.00 inch flywheel and how much input power are you placing on the flywheel. As far I as I know the 6 Speed typically had the 13 inch flywheel. I would still order a full kit including the flywheel if I was to replace your existing clutch. If you opt for re-using your old flywheel have it surfaced again and checked for true flat.
On my first truck the stock 5600 held fine with an EZ and rv275's  that was 325 at the wheels. I never got on the throttle at lower rpm's which I attribute to it's long service the stock clutch gave me. What killed is was getting on the throttle at low rpms. I was rolling through a turn in 3rd gear then got on it at low rpm's. Bye Felicia. STAAAAAANK. For the next few days you could smell my truck before you saw it.
Replaced with CON OFE. Great clutch. Towed real heavy with it and held everything I threw at it at that point.
I agree with what  @trreed says. Define your purpose then choose your clutch accordingly.
My little truck  had large twins, heavily fueled, and 6 x 13's.  There was a Valair Dual disc ceramic for the 4500. Fantastic clutch for it's purpose.
After replacing two clutch because the owners installed ceramic clutches and seeing them only last 40k on both trucks and eating the pressure plate in both trucks. Not a good clutch in my mind. Friction disc was like brand new in both cases.
Image result for mopar1973man ceramic clutch
Interesting.
As I stated "for it's purpose."
Not a daily or regular driver but a play toy that was taken out once in a while.
I'll either being doing another OFE or see what Valair offers for when the time comes in the new truck.
35 minutes ago, Ben said:
Interesting.
Some people don't understand "For It's Purpose" that's why I had to post those pictures too many people thought ceramic clutches are for a daily driver or towing applications which both trucks were used for. This is only reason I'm bringing this up. Not to point finger at you... :)
I agree.
I was going through valairs descriptions and the ceramic clutches stated not for towing.
23 minutes ago, Ben said:
I agree.
1
Again another point, the two guys I did the replacements for, have some fly by night shop do the clutch replacement. Of course the shop pushed the ceramic for daily driving and towing purpose. Just because a shop tech suggest a clutch doesn't mean it the correct clutch for the purpose. Then again none of these people did any research on proper clutch to install.
Sheesh.
In this day and age of information at our finger tips there  is zero reason not to be.
Edited by Ben
Makes people lazy, therefore the outcome
2 hours ago, CUMMINSDIESELPWR said:
nothing ive done will make it slip and i run 35" tires
 Sounds like a good clutch to consider, did you reuse your flywheel
I'm not sure if the 3rd gen NV5600 clutch and the 2nd gen NV5600 clutch are the same or not, by my OEM clutch held just find with the S-JR on the 40hp setting and towing, but it slipped the first time I tried the 100hp setting. It would only slip at 1400-1600 rpms but I pulled it within a couple weeks for a Con-OFE.
Looking back at my dyno sheets the power was about 290/610 on the 40hp setting and 385/710 on the 100hp setting. Stock was 285/520. That's all uncorrected at 2700' to the rear wheels, so use it for what you will. Flywheel hp/tq is approx 115% of rear wheel.
My next clutch will likely be the Con-OHD. My dad has a OHD and I like it a lot better than my OFE.
My current OFE has zero issues holding my 400/850 tune even WOT at 26K+.
Edited by AH64ID
I'm really curious what I have for clutch, po said it was just changed before I got it but nothing to special, I never slipped it yet easing in to it but if I try to lunch then it can slip. Guess I'll find out some day.
May I ask what the difference is?
Where are you dyno'ing at these days?
Smoother and quieter.
Smoother I could understand being the OFE can be a bit grabby. The quieter I don't understand being mine is silent. :think:
