Injector swap
25 minutes ago, jlbayes said:
I have attempted both ways (lines in place & lines removed). I had better luck with pulling the lines. Less fighting for me.
I tend to agree. Much easier with high-pressure lines removed. Still can be done with the high pressure lines in place. The only trick is to remove the 4 bolts hold the lines loosen all lines so the whole pack of 3 will flex. Then you get just enough room to pick out the crossover tubes. Just depends if you got times or not.
