Transmission dip stick question
My trans dip stick pops up a little, I shove it back down and 3 or 4 tanks worth of fuel later the dip stick has poped backed out maybe half inch.  Dont know what's causing it, vibration or pressure from venting is pushing it back out.  Been doing this for long time.
  Any ideas what's going on?
and if normal is it ok to put something on it to hold down to keep dust out?
Do you have this problem?
 Are other vent holes maybe  plugged and creating more venting out of dip stick hole?
Edited by 015point9
Correction
12 minutes ago, Marcus2000monster said:
I don’t see why you couldn’t use a pice if gorilla tape or something else to hold it down? I don’t have an auto trans so I can’t help anywhere else. Do you dhave I’ve much bumpy roads? Maybe worn out o ring around dipstick head?
Supposed to have o ring?  Never knew that. I'll check
Thanks
Mine has a rubber bushing at the top under the little metal cap the handle's attached to, but mine bounces out about a quarter inch soon as you push it in and want it to stay there it pops right back. At least the cap covers the fill tube mostly. It would be nice if it fit proper. Almost like the dip stick is too long and the bushing shrank.
Mine has metal bushing at top also.  Looks like a upside down bottle cap sortof?   Wonder if anything supposed to be inside the cap?
Yes inside the cap is a rubber bushing/ sleeved onto the dipstick and pushed up inside the cap. It seems that it shrank and won't hold snug to the tube any longer.
It wood be nice if it fit correctly, but I'm wondering if its designed to vent thru the tube instead.
Edited by JAG1
I'm wondering same thing on venting
Maybe Dynamic trans will see post and chime in.  He always has good info.
I wouldn't be concerned been coming up for long time.  And I think be exhaust brake install directions say in effect dip stick tube needs to be "modified".  In other words bend it out of the way.
  But I'm thinking dust could get inside.  Not so much when driving if trans is pushing positive pressure up tube but when sitting.  I'm guessing maybe another vent that might be plugged, creating more pressure thru dip stick tube.  But I dont see one and i know very little about trans.
Quote
Mine does the same thing.  Never  problem with it though,
The dipstick hits a shelf in the pan right under where the dipstick come into the case. For some reason Chrysler either used a dipstick that is too long (or a tube that is too short) in the 2nd Gen trucks. The 3rd Gens do not do this. A deep pan will fix it, or grind a little off of the end like Russ did. Keep in mind that the lower your dipstick sits in the pan, the less fluid you will have when it reads "FULL".
