Intermittent strange high idle.
26 minutes ago, Marcus2000monster said:
Also as i cruise down the hwy i will feel the pedal sort of go dead its not at all a major deal its very soft and hard to feel. its more of a hesitation than anything. Im thinking its got to be the injectors because i have no codes.
@cajflynn Do you think that the more you daily drive and tow with our trucks the longer they last?
This sounds like an APPS sensor to me.
14 minutes ago, Marcus2000monster said:
I thought so to but was told apps issues usally throw a code immediatly?
Typically yes. If the APPs falls out of range either hi or lo voltage it trips a code instantly and ignores the throttle signal for safety to prevent a WOT run away if it happens to be a hi volt issue.
Dang... I wish you had a Quad I tell you to just monitor the TPS signal and watch and see if it does anything strange during the dead pedal issue. You could do it if you have an OBD live data tool too but I'm not sure if you have one.
Shop has a Snap On Modus so i can watch it.
10 hours ago, Mopar1973Man said:
The only one close to me I think is good ol Dripley (David Ripley) he's about 100k miles ahead of me but we seem to average about the same amount of miles month to month for the most part. Even looking at his truck it's holding up rather well a bit more abused but doing good!
You are gaining on me. I am only making about 375/400 a week now.
By the above, are you making fun of my "maintenance schedules"?
Still proud of the miles I have gotten out of this truck but about to drop some cash with the head gasket. It will be agood time to clean up under the hood. Still all in all I have eneded up ahead on keeping the beast.
55 minutes ago, Mopar1973Man said:
362k miles... Still rolling the odometer...
1 minute ago, Dieselfuture said:
I believe after the hg you can get another 500k out of it without major engine work. Good luck with the hg job.
Probably the best purchase I have ever made on a vehicle. Thanks for the good wishes. I feel the same way.
Perhaps on my last ride in this truck my son will not feel the need to call ahead and ask them to dig a bigger hole. I am going to have a lot of fun with my son over that remark he made to me a while back. I hope I get many years out of it as I have the truck.
2 minutes ago, Marcus2000monster said:
I bought mine used and couldn’t be happier. Just have to work thru a few issues now and then.
The Dodge/Cummins has been amazingly reliable with only a few issues over the more than 19 years and 259K miles. I still enjoy driving it every time.
Me two! Hey I see you have a 6 speed and 3:54s. Do you like that? What rpm do you run on hwy? I just got a parts truck and am doing the swap.
The 6 speed is awesome and so glad I was able to order as equipped.  The truck was delivered with 245/75/16 Michelins and I've run a set of 235/85/16 for a few winters over the years....maybe 30k of the miles.
With the 245/75/16s the tach shows 1750 at 60 mph and it might be a hair over 60 ......this is in 6th gear.
On 11/28/2018 at 7:14 AM, Mopar1973Man said:
I can tell you that @cajflynn was a driving fool. (In a good way) I heard from him 800-mile day if possible. I tend to believe the more you use it the longer it will last. I'm nowhere near the level of driving that Cajflynn is but I'm much high than the average person here in M73M. The only one close to me I think is good ol Dripley (David Ripley) he's about 100k miles ahead of me but we seem to average about the same amount of miles month to month for the most part. Even looking at his truck it's holding up rather well a bit more abused but doing good!
I'm tagging along with @Mopar1973Man and @dripley with an easy 2.5-3k a month and running strong :thumbup2: at 352k
Edited by BBHD
Info
These truck are not designed to be driven short trip where the engine never builds full temperature. Really common out here where people live in a little town like Riggins, ID and never less than a full mile back and forth to work. A typical diesel engine will get washed out quickly because they never reach full temperature for very long if at all. Bad for even a gasoline engine to live that way. This is most of the reason why I've got good longevity from my truck. Riggins, ID is a 30-mile round trip. McCall is a 70-mile round trip. Either way I got I'm getting the full operating temperature and putting distance down. Ontario, OR trip for MoparMom is 250-mile round trip every Tues., Thurs., and Sat.
When you say full op temp you meaning 190* for coolant temp?
