- Replies 24
- Views 13.7k
dripley 5 posts
Dieselfuture 5 posts
Alexio Auditore 4 posts
Mopar1973Man 3 posts
It's a NV5600 so GL-4 isn't relevant... let's not create problems or confusion where it doesn't need to be. The NV5600 has never spec'd Gl-4, it specs syncromesh. Trying to make Syncromes
Close only works in horseshoes and hand grenades... It's not uncommon for fluid specs to be close, but not the same.. hence different specs. GL-4 fluids don't meet syncromesh, and syncromesh doesn't m
@Alexio Auditore You should have asked him to super size that fluid change. He might have understood that then asked if you wanted fries with it. I've worked in shops where they would hire a guys b
Hey, dont mean to start a new topic, but I have a question in regards to how much oil is in my 6 speed currently without draining it all.
Like how much oil can you put in from the fill hole on level ground? What about bolt at top of the pto?
Only asking because I had a shop( which does good work usually) drain and fill it. I would've done it myself but time is something I dont have a lot of.
I bought the oil, 6 quarts redline, and when I got truck back, I had 2 quarts of oil still left. Was told it may have had left over oil still in? Sounded odd, but they said they would check it. Brought It back, and a mechanic i havent met there came in and got me to show me it was filled to top of fill hole. He was a ****** about it too, so I questioned him on how much oil these transmissions take and he said " I just fill it to the oil comes out the top, I dont know." Wow ok, so i informed him on how much they take from factory spec, because apparently I have a moron working on my truck, then asked him to over fill it, which he knew they sometimes do it on these trucks. (Again, i trust the head mechanic and they usually do a great job, but this guy was something else.)
Anyway, i have a quart and a quarter still left over, and my truck isnt shifting into 4th and 5th smoothly at all. It's colder here now, which usually makes 3rd harder to shift into, but never had this kinda trouble with those gears. I do shift pretty slow, so it's not how fast i shift either. I feel like he didnt add enough oil, so I was gonna take the shifter off and add it through the top, I just want to make sure I dont put too much in there, especially if there was a quart still left in the truck when they drained it.
Plan on putting in 6 quarts. Is there a way to check how much is in there currently?
