We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 20
- Views 7.3k
Mopar1973Man 9 posts
AH64ID 3 posts
wil440 2 posts
ICU_24VNUT 1 post
No. Tricks or short cuts. Just filled with fuel, drove the distance and filled again. I need to restock on 2 cycle oil again. I really think the 3.69:1 final ratio helps a bunch just like
That's ~ $8.00 to $8.75 per gallon for us yanks!
Just know you may get the tables to make the same power, but EFI Live doesn’t offer all the tables that UDC Pro does. So if you want “full” control you may have to reconsider…
Did This Forum Post Help You?
"The Beast" Broke The High Mark 28.04 MPG On The Quadzilla!
Notify - @Quadzilla Power
Yup! The old high mark was 27.2 MPG with +75 HP injectors (Vulcan Performance) and Edge Comp.
Now I did it with a Quadzilla, +150 HP DAP Injectors, HX35/40 Hybrid Turbo. Netting 28.04 MPG hand math, fill to fill!
So I filled up in Riggins, ID and then drove to Donnelly, ID to get my paycheck for my last 2 weeks of work. Now returned home which included sitting in construction in McCall for about 15 minutes idling with A/C running. Next morning I got up and drove to Lewiston Idaho. When I got to Lewsiton, ID I was shocked to look down at just below 7/8 of tank and 236 miles. After I was done shopping I racked up 263 miles and I filled up again at 3.509 a gallon which is cheap compared to 4.209 up here at home.
With fuel at $4 plus a gallon at home this truck is going to be my eco-friendly diesel truck. All I did was drive normally light acceleration, CANBus fuel only no wire tap used, and set the cruise for speed limit. Nothing fancy.
Fuel gauge when I hit Lewiston, ID
Then the Trip in miles and my odometer is on the mark... It is calibrated for my 245's tires.
Then the data in my fuel log...
