- Replies 29
- Views 7k
Mopar1973Man 9 posts
YeaImDylan 6 posts
jlwelding 3 posts
wil440 3 posts
I've got a set of 100 hp 7x.009 VCO injectors from DAP, very happy with them.
Yep, I just installed 50hp injectors from DAP and a rebuilt and balanced driveshaft a few hours ago. As soon as the air cleared the system I was like wow, thats a awesome sounding eng. I didnt know wh
I just came back from Roseville pulling my travel trailer. Mostly flat ground. Took 1/2 a tank. I believe about 230 miles to my sisters house. Checked my mpg once I topped off there. I got 12.66 mpg.
Hey all, if any of you saw my fuel in oil post, I'm planning to upgrade my injectors a tad bit. Planning to go with 150s from 125s and then I'll be done adding power to the truck unless I come across a lot of money lol. I'm debating on going "cheap" and getting 7x010 VCO from DAP. If I got this route, should I just do the remans or do I get the new Bosch bodies? What's the biggest difference in these injectors when it comes to brand? They all seem to be Bosch injectors with bigger holes... So I wonder why buy one that is more expensive? Other brand I'm looking at is Infinite, 1BadVP44 sells them and TJ seems to love their injectors. There's a chance my injectors are fine and my seals happened to fail in only exactly a year's time... Just don't want to send them off for testing for a couple hundred when I can just get new ones and a bit higher HP. Open to all thoughts on this and if more info is needed, let me know!
Thank you!
Dylan
