Here is my deal, My truck was running fine then just died sort of felt like it jumped out of gear but that could of been the loss of power. Refire run really rough only idle no foot feet response. Now doesn't start at all. So what I have learned so far is pump must of went.So my truck is a 99 but I have a pump on a 2001 motor is it the same? I sort of want to be sure I'm 600 miles from the 01 pump and don't want to rent a car and drive that far if it might not work. Thanks
  • Replies 11
Welcome to the site... Sorry to hear about your problems. :duh:But as for the VP44 as long as VP44 is the same (SO VP44 installing to SO Engine) there should be no problems. It should work. Just make sure to keep the key match with its pump. But if the 01 happens to be a 6 speed then you need a HO VP44 pump.
Like Mike said, if your 99 has a five speed, then the 01 needs to be a five speed also. If the 01 is a six speed then it is a high out put motor and it will not work on you 99 five speed because it is a standard out put.
Where are you located at currently?Try the easy stuff first.You might try resetting the APPS, as it might have lost its settings. Truck dying going down the road, then the idle being erratic. Then no response from pushing on the skinny pedal.Does your lift pump turn on when you bump the starter(not starting the truck).Do you know if the '01 engine is an H.O. Have someone there look at the injection pump and see if it has 235(S.O.) or 245(H.O.) on the label.
Thanks Well I'm in SE MN out side RochesterI got a 1688 and 1689 codeIt was a auto tranny the 01 so it's not a HOI have a aftermart lift pump and it's working and the factory one runs alsoI was just leaving a stop sign and as I was picking up speed I shifted into 3rd and it jump like the tranny popped out of gear but when I put in the clutch it died and when I restarted it it ran rough and had not thottle response at all. Restarted about 3 times and now doesn't start, it fires after crancking on it for a few seconds but thats it. Thanks agian
Thanks Well I'm in SE MN out side Rochester I got a 1688 and 1689 code It was a auto tranny the 01 so it's not a HO I have a aftermart lift pump and it's working and the factory one runs also I was just leaving a stop sign and as I was picking up speed I shifted into 3rd and it jump like the tranny popped out of gear but when I put in the clutch it died and when I restarted it it ran rough and had not thottle response at all. Restarted about 3 times and now doesn't start, it fires after crancking on it for a few seconds but thats it. Thanks agian
P1688 code http://forum.mopar1973man.com/threads/2627-P1688-Internal-Fuel-Injection-Pump-Controller-Failure P1689 code http://forum.mopar1973man.com/threads/2628-P1689-No-Communication-Between-ECM-and-Injection-Pump-Module
Thanks for the bad news Mike.
You know you can get both of those codes when you run out of fuel or have a bad battery.
  • Current Donation Goals
    • Raised $20
