- Replies 39
- Views 33k
Mopar1973Man 6 posts
BART 5 posts
pepsi71ocean 5 posts
98whitelightnin 3 posts
if you can adjust the valves, changing the injectors i think would be easier.just got to folow the steps, mainly when putting it all back together, drop in the injectors but dont lock em down then ins
TH Racing is right RV275 is a really good mild injector... I'm running RV275's and Edge Comp as well... EGT's are in check no problems with EGT's with towing either. As for doing both projects... ht
I know this has been hashed about before but I gotta ask. I'm thinking about a set of RV275's for my mostly stock '02 with 118,000 miles, see other stuff in my signature. I do haul a pretty heavy camper and tow a boat. The truck has a Quad ZXT+ chip thingy (pretty mild by most standards). My question is...amd I just wasting my $'s or will I see a REAL difference?Second question: Can I install them myself? I not a total idiot with a wrench and can follow directions. I was thinking it's also about time to adjust the valves too. Thanks to all for opinions.
