Quick question
Mike, I just looked there is a vent comes out right above the starter and hangs down behind it. I guess the dealer when they had it in for a recall did the TSB. I ordered the truck special, I don't guess they would of done this at the factory. Looks like a lot of work otherwise.
I talked to a buddy in Louisana (towhungerford) he told me the 12V tappet covers will fit a 24V block so if you which to just change out the cover and put a old school 12V tappet cover on you can...
I take the 12v tappet cover works just as good for venting without the oily mess of the puke bottle?
yeah the 12v tappet cover is interchangeable and a number of guys run them during a replacemain problem is havent found a decent one cheap and used is always risky on a cover like that - although the gasket is seperate anyway I thinkthinking when I finally pull mine - might just go billet and be done with it....
