Towing and tire chains
- Replies 17
- Views 4.7k
CSM 3 posts
AH64ID 2 posts
IBMobile 2 posts
joecool911 2 posts
Popular Days
I was just going to bring up Oregon chain laws. If chains are required and you are towing you are required to chain the trailer. I have driven MANY MANY roads in the winter (with and without a trailer
I would just base your travel on the weather. If the weather gets bad I would just hole up for the night or period of time till the storm passes. I would gear up the truck with everything you might ne
You said Save your money and use it for a warm motel if you need to. it's better that staying in a cold truck stop
For light duty vehicles with good tires, I have always been of the opinion that if I need chains I shouldn't be making the trip. Sofar, through CO, WY, UT, ND, SD, MT & NM oilfield travel in all weather, I haven't been wrong.
However, I don't normally tow in the winter. As an engineer, I didn't have to drive the 18 wheelers to location, and they were almost always chained on all drives, steers, and at least one set of drags. I am going to have to tow my household home from AR to CO this winter (Jan-Feb). I am on the fence if it would be a wise move to buy chains for my truck and the rear axle on my trailer. Pix of trailer below. The cost will be pretty steep for something I may only use once, and then perhaps not at all, especially as there aren't any real mountains between me and home. I would use the chains as "get to a truck stop" chains only, not as I am going to slog through the last 300 miles at 30mph chains.
Any experience here?
I am looking at the below chains.
http://www.amazon.com/gp/product/B000VAJ17M?colid=186EVLBXUUHHS&coliid=I2FLZMMGO3WLN5&psc=1&ref_=wl_it_dp_o_pC_nS_ttl
