- Replies 33
- Views 6.5k
								Mopar1973Man 4 posts
								KATOOM 4 posts
								AH64ID 4 posts
								TFaoro 4 posts
								for me if you are not doing extreme offroading, get the spicer ujoints with the grease nipple. I do a lot of offroading and want the extra strength so i go with the non greaseable ujoints. the non gre
								I do not do a lot of offroading like CDP but still have the OE joints on my truck. Spicer non greseable is what is on it and I would be hard pressed not to put the same back on it. 375lk miles on the
								I no longer run greasable and only use Spicer non-greaseable. Why.....? Because greaseable has a weak single seal to allow grease to escape as you pump in new goo. That single lip seal also allows
What u-joint brand for the front wheels, do people recommend? (Most reliable/strongest, affordable.)
