No clutch pedal, can't get NV4500 into gear
- Replies 22
- Views 10.1k
Mopar1973Man 7 posts
joecool911 3 posts
dripley 2 posts
leathermaneod 2 posts
Even buying the part separated from Autozone you can do it for $95... that's a $55 dollar saving do it your self and bleeding the system out before you install it. http://www.autozone.com/
Check under the dash for fluid leaks at the push rod of the clutch pedal.
Not something I'd suggest either for no good reason. But to get home, it'll work. Better than a tow.
So, I was towing my boat back and no issues until I went to put it in reverse. It was acting like it was stuck. After I backed in the boat, I put the brake on, unhooked the boat. Jumped back in and then tried putting it in first, with the brake on...
So, soon after getting home that I tried to put it in reverse and no go. the pedal went right to the floor, and it would not go into gear unless the engine was off.
Is this a broken clutch fork, stuck throwout bearing.and do I need a new clutch master/salve cylinder? I rebuilt the tranny last year, replaced the clutch 2 years ago, and now have 350,000 miles, with about 70k on the clutch.
Thanks for any help
GSX455
