- Replies 27
- Views 7.3k
Mopar1973Man 7 posts
KATOOM 3 posts
TFaoro 3 posts
Me78569 2 posts
First of all, I just want to point out that the antifreeze smell in the cab could be your heater core leaking. You can check the passenger side floor and firewall to see if you can find anything wet w
Take notice to my coolant gauge here I've marked the green area as normal. You can see the open temperature of my thermostat. So I would have to say your thermostat is sticking.
I think the limits are actually 162.5 and 222.5
Hello everyone, I'm new to the site and this is my first diesel. I just picked up a 99 2500 long bed 4x4 5 speed manual. Truck has 310k on it and according to the service records the truck has been maintained well. My question is what temp should the thermostat open up at? When driving from cold the thermostat goes past 190 to probably 215 or 220 then opens up and drops back down to 180-190. It never over heats, but it is the initial opening that makes me wonder if the thermostat is sticking. When it goes over 190 the cab has a little bit of a sweet antifreeze smell but I have checked under the hood and there are no leaks. It just smells hot when it first opens up. I can drive the rest of the day and not have that issue at all. Is this normal for this truck? Truck has the idiot fuel pressure light and a 4" exhaust from the cab back.
