- Replies 16
- Views 4.4k
Yes, like Mike said, loosen the VB bolts enough to separate it from the case a crack and then wait for it to stop dripping. This will allow the converter to drain back (to the level of its hub, anyway
It's easy to get all the fluid out if you take it apart
Like Dynamic told me just loosen the valve body a bit and allow it to separate from the transmission and it will drain most out of the torque converter.
Last night i did a transmission fluid change, filters and bands. All went well with the service portion. Real wtf moment was when referring to the chiltons manual and it told me that it only takes 3 PINTS.
uhm, no. The was more than just 3 pints in the pan when i dropped it. When i bought the fluid from the auto store, guy told me his computer told him 4 quarts. So i obliged and bought 4 quarts.
I poured in 3 and got a reading. Ran the gear selector through all gears then put in neutral. Said it was still good. Then i took it for a test drive. Initially, it wouldn't move then a moment later i had pressure.
I put in atf4+ this time. Dunno what the shop put in originally. Hopefully there are no issues with the two fluids in the transmission. Anyways, the truck shifted like dream. Night and day difference. Could hardly tell it was shifting.
So today i did my fuel line service. Which is in the other thread. So i wanted to treat drive again. I check the fluid again and didn't even read on the stick! Wtf..
So i thought maybe cause it's just a fluke. Cause it drove just fine yesterday. Well i go to pull out of the driveway and the truck dies on me. I was okay, i guess I'll put quart 4 in. So let her have it all.
Started it up and she drove fine for the test. Wasn't shifting as smoothly as before. Get back to the house and check fluid again. In neutral after warming up, trans temp was 150. Couldn't get it any hotter. It still would not read on the stick!
I felt like i was going crazy and thought i was losing fluid. I know i torqued all the bolts and did everything right.
What the heck is the real fluid change capacity after servicing the transmission?? I googled up on it and some say 6 quarts. Anyone know how much it takes?
Can't believe chiltons manual said 3 pints....
