- Replies 20
- Views 9k
Me78569 6 posts
903Dodge 6 posts
notlimah 2 posts
Mopar1973Man 1 post
Finally got around to building and doing a boost leak test. Only leak I found was at the rubber hose going to the boost elbow. I also got to messing with the setting on my Quad and have fi
Test for boost leaks. You should be spinning that turbo to mars with the fuel you have. I would expect 40+ psi.
not really depending on the use of the truck. The quad also ramps down slow so you might see higher than that EGT's if you have a load on it. 1150 will give you a good safe buffer.
I have run into a problem with my current setup with my egts while towing no matter what I have my my quadzilla set on.
If I continue to tow a lot what turbo should I upgrade to or should I go back to stock injectors?
The turbo is the original HX35.
If I upgraded turbo I just want a direct bolt on.
Thank an you for your input.
